[gdal-dev] Q: on gdalwarp of ecw file
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Dec 17 11:50:27 PST 2012
Hi all,
I have an ECW file, see gdal info below. I need to reproject this into
EPSG:900913 or EPSG:3857
Do I need a key to make the output file ECW?
The performance vs size when zooming out is impressive with ECW, but it
does not look like I have ability to create ECW. Are there better
formats then GTif in the list below?
$ gdalwarp -t_srs EPSG:900913 -of GTiff -co TILED=YES -co COMPRESS=JPEG
Saraji_South.ecw Saraji_South-900913.tif
Creating output file that is 34551P x 32332L.
Processing input file Saraji_South.ecw.
0...10...
This seems to be working, I suspect this will bulk up after I add overviews.
Thanks,
-Steve
$ gdalinfo --formats | grep ECW
ECW (rw): ERDAS Compressed Wavelets (SDK 3.x)
JP2ECW (rw+v): ERDAS JPEG2000 (SDK 3.x)
i$ gdalwarp -t_srs EPSG:900913 -of ECW Saraji_South.ecw
Saraji_South-900913.ecw
Output driver `ECW' not recognised or does not support
direct output file creation. The following format drivers are configured
and support direct output:
VRT: Virtual Raster
GTiff: GeoTIFF
NITF: National Imagery Transmission Format
HFA: Erdas Imagine Images (.img)
ELAS: ELAS
MEM: In Memory Raster
BMP: MS Windows Device Independent Bitmap
PCIDSK: PCIDSK Database File
ILWIS: ILWIS Raster Map
SGI: SGI Image File Format 1.0
Leveller: Leveller heightfield
Terragen: Terragen heightfield
netCDF: Network Common Data Format
HDF4Image: HDF4 Dataset
ISIS2: USGS Astrogeology ISIS cube (Version 2)
ERS: ERMapper .ers Labelled
JP2ECW: ERDAS JPEG2000 (SDK 3.x)
RMF: Raster Matrix Format
RST: Idrisi Raster A.1
INGR: Intergraph Raster
GSBG: Golden Software Binary Grid (.grd)
PNM: Portable Pixmap Format (netpbm)
ENVI: ENVI .hdr Labelled
EHdr: ESRI .hdr Labelled
PAux: PCI .aux Labelled
MFF: Vexcel MFF Raster
MFF2: Vexcel MFF2 (HKV) Raster
BT: VTP .bt (Binary Terrain) 1.3 Format
LAN: Erdas .LAN/.GIS
IDA: Image Data and Analysis
GTX: NOAA Vertical Datum .GTX
NTv2: NTv2 Datum Grid Shift
ADRG: ARC Digitized Raster Graphics
SAGA: SAGA GIS Binary Grid (.sdat)
$ gdalinfo Saraji_South.ecw
Driver: ECW/ERDAS Compressed Wavelets (SDK 3.x)
Files: Saraji_South.ecw
Saraji_South.eww
Size is 34361, 31930
Coordinate System is:
PROJCS["SUTM55",
GEOGCS["AUSTRALIAN GEODETIC",
DATUM["AGD66",
SPHEROID["ANS",6378160,298.25]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",147],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",10000000],
UNIT["Meter",1]]
Origin = (627267.025999999954365,7521500.000000000000000)
Pixel Size = (0.500000000000000,-0.500000000000000)
Corner Coordinates:
Upper Left ( 627267.026, 7521500.000) (148d14'11.23"E, 22d24'28.15"S)
Lower Left ( 627267.026, 7505535.000) (148d14'15.84"E, 22d33' 7.25"S)
Upper Right ( 644447.526, 7521500.000) (148d24'11.99"E, 22d24'23.24"S)
Lower Right ( 644447.526, 7505535.000) (148d24'17.23"E, 22d33' 2.31"S)
Center ( 635857.276, 7513517.500) (148d19'14.07"E, 22d28'45.31"S)
Band 1 Block=34361x1 Type=Byte, ColorInterp=Red
Overviews: 17180x15965, 8590x7982, 4295x3991, 2147x1995, 1073x997,
536x498, 268x249
Band 2 Block=34361x1 Type=Byte, ColorInterp=Green
536x498, 268x249
Band 3 Block=34361x1 Type=Byte, ColorInterp=Blue
536x498, 268x249
