[gdal-dev] Q: on gdalwarp of ecw file
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Dec 17 14:54:23 PST 2012
On 12/17/2012 5:02 PM, Stephen Woodbridge wrote:
> On 12/17/2012 4:54 PM, Even Rouault wrote:
>>> Second problem, when I try to convert it to a tif it always dies like
>>> this:
>>> $ gdalwarp -t_srs EPSG:900913 -of GTiff -co TILED=YES -co COMPRESS=JPEG
>>> -co PHOTOMETRIC=YCBCR Saraji_South.ecw Saraji_South-900913.tif
>>> Creating output file that is 34551P x 32332L.
>>> Processing input file Saraji_South.ecw.
>>> 0...10...20..ERROR 1: Could not perform Read/Write on file
>> Hum, did you check if you have enough disk space ?
> target disk has 200GB but maybe the /tmp is small, is there a way to set
> an environment variable to open tmp file elsewhere?
Hi Even,
This is not related to disk space. I just monitored with df and there
were no problems, and not even a close call on space.
gdalwarp creates the file and actually writes some to it:
$ gdalwarp --config CPL_TMPDIR . -t_srs EPSG:900913 -of GTiff -co
TILED=YES -co COMPRESS=JPEG -co PHOTOMETRIC=YCBCR Saraji_South.ecw
ls -l Saraji_South-900913.tif
-rw-r--r-- 1 woodbri woodbri 57130007 2012-12-17 17:43
I renamed the file and run the command again, it creates another file of
exactly the same size.
-rw-r--r-- 1 woodbri woodbri 57130007 2012-12-17 17:57
Saraji_South-900913a.tif
And they appear to byte for byte identical using cmp.
Thanks,
-Steve
