[gdal-dev] Q: on gdalwarp of ecw file
Jan Hartmann j.l.h.hartmann at uva.nl
Tue Dec 18 04:27:34 PST 2012
Thanks Jukka, I always wanted to learn Finnish :-). Almost as difficult
as Dutch.
Cheers,
Jan
On 12/18/2012 01:16 PM, Jukka Rahkonen wrote:
> Here is a fresh table comparing resampling methods and cgi vs. fast-cgi with
> Mapserver and with raster map data.
> http://latuviitta.org/Apps4Finland-2012/documents/Taustakartta_WMS_kapasiteetti.html
> Titles are in Finnish but you can make it with this lexicon
> näytteitä=samples
> vasteaika=response time
> keskiarvo=mean
> kuvaa/sek=images per second (800x600 pixels)
> Thus you can get either 17.3 images per second or 63.7 from the same source data
> just be changing Mapserver/GDAL options. Naturally the quality is not the same
> which is another prove for considering the whole system instead of optimizing a
> single piece of it.  By the way, numbers show that "cgi slow-fast-cgi fast" is
> not the whole truth either. If there is lot of computing with bilinear or
> average resampling the difference in speed is nominal and cgi is much more
> stable - look at then maximum response time field.
> -Jukka-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121218/be435c50/attachment.html>
