[gdal-dev] write pseudocolor raster
Agustin Lobo
alobolistas at gmail.com
Sun Dec 23 05:40:59 PST 2012
I have some 1-band raster layers that I would like to write as
pseudocolor files. Is it
possible to use gdal_traslate or another gdal utility to write the
raster using the color palette
of another file?
I've seen the procedure described in
http://trac.osgeo.org/gdal/wiki/FAQRaster#Howtocreateormodifyanimagecolortable
but I would like no having to edit the vrt file manually.
Thanks
Agus
