[gdal-dev] Multithreaded GDAL
Livneh Yehiyam yehil at rafael.co.il
Mon Dec 24 06:04:26 PST 2012
Hi all
I've tried searching for an answer online, but the most recent information I found is more than 3 years old.
We have method that reads pixels from one data-source, performs some manipulation, and writes it to another.
Reading is done with the Band.ReadRaster C# API.
Writing is done with the Band.WriteRaster c# API.
I'd like to process several data-sets in parallel on multiple threads.
>From what I could understand from http://trac.osgeo.org/gdal/wiki/FAQMiscellaneous and other online sources, "no threads can be writing to GDAL while others are reading".
Has this changed in recent versions? Is it now possible to read and write on different threads (from different data-sets)?
Thanks
Yehiyam
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD.
(hereinafter "RAFAEL") contains confidential information intended for a specific individual and purpose, may
constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not
the intended recipient, you should contact us immediately and thereafter delete this message from your
system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this
message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error,
please notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely delete or destroy any and all
electronic or other copies of the original message and any attachments thereof.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121224/17ff71b3/attachment.html>
