[gdal-dev] Overviews using GDAL
Dmitry Baryshnikov
bishop.dev at gmail.com
Wed Dec 26 01:48:38 PST 2012
Hi Hari,
26.12.2012 9:16, HariPrasad ?????:
> Hi Dmitry
> I was inspecting various GDAL sources
> (http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts). I was bit confused
> how to implement RasterIO method. Which format to look for better idea.
By my opinion the best format is geotiff
> Should i call IRasterIO() method in IReadBlock?
> /CPLErr RBDRasterBand::IReadBlock( int nBlockXOff, int nBlockYOff, void *
> pImage )
> return IRasterIO( GF_Read, nBlockXOff, nBlockYOff, nBlockXSize,
> nBlockYSize,
> pImage, nBlockXSize, nBlockYSize, eDataType,
> GDALGetDataTypeSize(eDataType)/8, 0 );
> /CPLErr RBDRasterBand::IRasterIO( GDALRWFlag eRWFlag,
> int nBlockXOff, int nBlockYOff, int
> nXSize, int nYSize,
> void * pData, int nBufXSize, int
> nBufYSize,
> GDALDataType eBufType,
> int nPixelSpace, int nLineSpace )
> //my logic
> Earlier we were using ERDAS method to get the handle
> /long LayerRasterRead( void *lHandle, unsigned long bRow, unsigned long
> bCol,
> unsigned char **pixels )
> //logic
> Is there any method similar to get the handle in GDAL?
The best starting point is http://gdal.org/gdal_tutorial.html but in
example shown reading of one line of the image.
Reading the whole image will looks like this:
int nPixelSpace(0);
int nLineSpace(0);
int nBandSpace(0);
if(nBandCount > 1)
int nDataSize = GDALGetDataTypeSize(eDT) / 8;
nPixelSpace = nDataSize * nBandCount;
nLineSpace = nBufXSize * nPixelSpace;
nBandSpace = nDataSize;
void* data = CPLMalloc (nWidth * nHeight * nDataSize *
nBandCount); //allocate memory for pixels
pGDALRaster->RasterIO( GF_Read, nXOff, nYOff, nXSize, nYSize, data,
nWidth, nHeight, eDT, nBandCount, panBandList, nPixelSpace, nLineSpace,
nBandSpace);
Details:
http://gdal.org/classGDALRasterBand.html#a5497e8d29e743ee9177202cb3f61c3c7
If nWidth != nXSize and nYSize != nHeight the closest overview will be
used for fast access to pixel data.
If eDT == /GDT_Byte/you can write: unsigned char* pixels = (unsigned
char*) data;
> View this message in context:http://osgeo-org.1560.n6.nabble.com/Overviews-using-GDAL-tp5022226p5024588.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121226/9d3216e7/attachment.html>
