[gdal-dev] Compression artifacts
Jan Hartmann j.l.h.hartmann at uva.nl
Thu Dec 27 04:59:49 PST 2012
That would be an option. Am I right that the datasource of the -cutline
option is a closed polygon, and that everything outside the polygon will
be clipped?
However, I would prefer not to add extra steps. These are large maps and
there are lots of them (about 17.000 for the whole of the Netherlands).
It takes a lot of organisation to georeference them and display them
efficiently over the web. Every additional processing step is a
potential source of problems. So, although I am happy there is at least
a workable solution, do you know what is happening here, and whether
these artifacts can be prevented?
On 12/27/2012 01:44 PM, Dmitry Baryshnikov wrote:
> Hi Jan,
> You can cut result raster with the geometry (shape file) using
> gdalwarp with cutline option (http://gdal.org/gdalwarp.html).
> Best regards,
>     Dmitry
> 27.12.2012 16:38, Jan Hartmann ?????:
>> Can anyone tell me wath is happening here? I have a large three-band
>> raster (3.8G) looking like this:
>> http://mapserver.sara.nl/map2a.png
>> I compress it (from information from this list a few days ago) with:
>> gdal_translate -co COMPRESS=JPEG -co PHOTOMETRIC=YCBCR big.tif small.tif
>> gdaladdo --config COMPRESS_OVERVIEW JPEG --config
>> PHOTOMETRIC_OVERVIEW YCBCR -ro -r gauss small.tif 2 4 8 16 32 64
>> and get a file of 37M, which is nice. However, the map has all kinds
>> of rubbish at the borders. It looks like this:
>> http://mapserver.sara.nl/map2b.png
>> The equivalent pictures of a small part of the map look like this:
>> http://mapserver.sara.nl/map1a.png
>> http://mapserver.sara.nl/map1b.png
>> Can anyone help me?
>> Jan
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121227/906997de/attachment.html>
