[gdal-dev] bug in OGRGeometryTypeToName
Ben Discoe
ben at vterrain.org
Sun Dec 30 22:06:03 PST 2012
Unless there's something I'm not understanding, it seems there is a highly
visible bug in OGRGeometryTypeToName() in GDAL 1.9.2. Namely, it says that
all 3D types are 2D, and 2D types are 3D. See ogrgeometry.cpp:
bool b25D = wkbFlatten(eType) != eType;
switch( wkbFlatten(eType) )
case wkbUnknown:
if( b25D )
return "Unknown (any)";
else
return "3D Unknown (any)";
See how it returns "3D" in the non-b25D case.
This can be easily demonstrated with ogrinfo on a 2D file (in this case
wkbLineString):
ogrinfo Contour.shp
INFO: Open of ` Contour.shp'
using driver `ESRI Shapefile' successful.
1: Contour (3D Line String)
Maybe this bug is already fixed in HEAD?
Thanks,
Ben
