[gdal-dev] numpy array to raster
Anton Korosov
anton.korosov at nersc.no
Wed Feb 1 03:12:17 EST 2012
Probably the problem is with data type. You obviously have data of float
type and you give GDT_Byte to the gdal.GetDriverByName('GTiff').Create().
Either try to create array with Byte data or give GDT_Float32. In the
latter case the produced geotiff will have 32 bits fo each pixel. It is
not supported by simple viewers but should be read with ArcGIS.
On 02/01/2012 03:31 AM, questions anon wrote:
> no I quickly checked that!
> myarray is:
> [[ 16.15035553 16.14380074 16.15581551 ..., 18.06388149 18.08930645
> 18.08825245]
> [ 16.2154911 16.21180592 16.23977184 ..., 18.1085537 18.12040272
> 18.12342682]
> [ 16.32851467 16.29202938 16.28964043 ..., 18.16753635 18.14905453
> 18.16632977]
> [ 30.50812759 30.58384018 30.66707535 ..., 26.31020527 26.47789459
> 27.11495361]
> [ 30.76499577 30.76497536 30.79138317 ..., 26.45928288 26.64059887
> 27.03641129]
> [ 31.01263275 30.96269417 30.9933857 ..., 26.78247185 26.77845631
> 26.97975636]]
> On Wed, Feb 1, 2012 at 1:25 PM, Kyle Shannon <ksshannon at gmail.com
> <mailto:ksshannon at gmail.com>> wrote:
> Is 'myarray' full of zeros?
> * Kyle Shannon
> * ksshannon at gmail.com <mailto:ksshannon at gmail.com>
> On Tue, Jan 31, 2012 at 19:20, questions anon
> <questions.anon at gmail.com <mailto:questions.anon at gmail.com>> wrote:
> thanks Frank, following your instructions with:
> src_ds=gdal_array.OpenArray(myarray)
> dst_ds =
> gdal.GetDriverByName('GTiff').Create('E:/test/rasterise/mynewraster.tif',ncols,
> nrows, 1 ,gdal.GDT_Byte)
> dst_ds.SetGeoTransform(geotransform)
> dst_ds.GetRasterBand(1).WriteArray(myarray)
> I do not receive any error messages but the tiff produced are
> all just zeros. Is there a step I am missing?
> thanks
> On Wed, Feb 1, 2012 at 12:07 PM, Frank Warmerdam
> <warmerdam at pobox.com <mailto:warmerdam at pobox.com>> wrote:
> On Tue, Jan 31, 2012 at 4:38 PM, questions anon
> wrote:
> > I need to output my numpy array as a raster so that
> someone else can access
> > the data in ArcGIS. So basically the steps I need are:
> > read numpy array into gdal
> > convert to raster
> > use latitude and longitude and array size to set projection
> > I am really struggling with gdal because I can't seem to
> find enough
> > documentation about each step to understand what it is doing.
> > Here are some of the steps I think I need:
> > myarray=myarray
> > #the extent and shape of my array
> > xmin,ymin,xmax,ymax=[139.8,-39.2,150.0,-33.6]
> > ncols,nrows=[193,106]
> > xres=(xmax-xmin)/float(ncols)
> > yres=(ymax-ymin)/float(nrows)
> > geotransform=(xmin,xres,0,ymax,0, -yres)
> > from osgeo import gdal
> > from osgeo import gdal_array
> > dst_ds =
> > dst_rb = dst_ds.GetRasterBand(0)
> > output = gdal.RasterizeLayer(dst_ds)
> Dear "Questions Anon",
> There are a variety of Python related information at:
> http://trac.osgeo.org/gdal/wiki/GdalOgrInPython
> One serious issue with the above is that
> "gdal.RasterizeLayer()" is used to
> turn vector data into raster data - for instance to
> rasterize polygon features
> into an existing raster file. I think you want to write
> your array into a
> raster file. I think you can just call
> "dst_ds.WriteArray(myarray)".
> Alternatively if that method does not exist on the dataset, you
> can write the one band like:
> Some of the samples referenced from the GdalOgrInPython
> should be
> helpful though I understand it can be hard to know where to
> look.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows |
> http://pobox.com/~warmerdam <http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | Geospatial Software
> Developer
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
