[gdal-dev] Missing EPSG Codes and importFromUrl
Andy Cheetham
andy.cheetham at geomaticsolutions.com
Fri Feb 3 02:44:33 EST 2012
You could try our website the GeoRepository.com
It will provide you with all the details of the CRS in question
http://georepository.com/search/by-name/?query=4418
Hope this helps
Andy Cheetham
On 2 Feb 2012 23:33, "David Baker (Geoscience)" <david.m.baker at chk.com>
wrote:
> All,
> Working in C#... I have need for EPSG:4418. Per
> http://www.epsg-registry.org/ this is the code for “ProjectedCRS [NAD27 /
> BLM 18N (ftUS)]”. This code does not seem to be in the GDAL/OGR/Prog4
> database in FWTools2.4.7. Executing the line:
> var i = src.ImportFromEPSG(4418);
> This call returns an error indicating the code is invalid. I also
> searched the /data directory for this projection but was not able to find
> it. So my next move was to try:
> var i = src.ImportFromUrl(@"
> http://www.epsg-registry.org/export.htm?gml=urn:ogc:def:crs:EPSG::4410");
> This did not work either.
> So my general question is, for missing CRS’s how does one retrieve the
> projection information from the web?
> Thanks in Advance,
> David
> *David M. Baker*
> Senior Advisor – Geoscience Technology
> Chesapeake Energy Corporation
> 405-935-3715 office
> 405-496-5373 cell
> This email (and attachments if any) is intended only for the use of the
> individual or entity to which it is addressed, and may contain information
> that is privileged, confidential and exempt from disclosure under
> applicable law. If the reader of this email is not the intended recipient,
> or the employee or agent responsible for delivering this message to the
> intended recipient, you are hereby notified that any dissemination,
> distribution or copying of this communication is strictly prohibited. If
> you have received this communication in error, please notify the sender
> immediately by return email and destroy all copies of the email (and
> attachments if any).
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120203/2d480605/attachment.html
