[gdal-dev] OGR building always requires KML, GML, GEOJSON drivers
Dmitry Baryshnikov
polimax at mail.ru
Sun Feb 5 08:34:59 EST 2012
05.02.2012 16:55, Chaitanya kumar CH пишет:
> Dmitry,
> I not sure about KML and GeoJSON, but the GML driver need not be
> enabled for the exportToGML method to work. Even for the other two,
> the code associated with exporting the OGRGeometry to those formats
> seems to stand apart from the driver code.
I want to build GDAL without GML, KML and GEOJSON and I cannot do it
because dependencies. I don't need exportToGML, exportToKML,
exportToJson working in this library (as I don't check this drivers to
build). The adding of ifdef will solve this.
> Also, these functions are occasionally used irrespective of the drivers.
> Check if there are any problems when the KML and GeoJSON drivers are
> disabled. If there are any, it's better to add your patch.
> On Sat, Feb 4, 2012 at 10:45 PM, Dmitry Baryshnikov <polimax at mail.ru
> <mailto:polimax at mail.ru>> wrote:
> Hi all,
> OGRGeometry have such methods as exportToGML, exportToKML,
> exportToJson which always requires KML (not LIBKM), GML and
> GEOJSON code.
> I think in exportToGML, exportToKML, exportToJson should be #ifdef
> KML_ENABLED GML_ENABLED, GEOJSON_ENABLED.
> For example:
> char *OGRGeometry::exportToKML() const
> #ifndef _WIN32_WCE
> #if defined OGR_ENABLED && defined KML_ENABLED
> return OGR_G_ExportToKML( (OGRGeometryH) this, NULL );
> #else
> CPLError( CE_Failure, CPLE_AppDefined,
> "OGRGeometry::exportToKML() not supported in
> builds without OGR drivers." );
> return NULL;
> #endif
> #else
> "OGRGeometry::exportToKML() not supported in the
> WinCE build." );
> return NULL;
> #endif
> Can I add such code?
> Best regards,
> Dmitry
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
Best regards,
Dmitry
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120205/52a1b97a/attachment.html
