[gdal-dev] gdal_polygonize error with Arc/Info binary grid
Vish Uma
viswaug at yahoo.com
Tue Feb 7 15:16:11 EST 2012
Hi all,
I am trying to convert an Arc/Info binary grid raster file to a shapefile
using the gdal_polygonize.py utility. But the operation fails with the
following error
*Warning 1: Unsupported Arc/Info Binary Grid tile of type 0x80 encountered.
This and subsequent unsupported tile types set to no data value.*
Here is a screenshot of the error
http://osgeo-org.1560.n6.nabble.com/file/n4373658/Capture1.png
I am able to open and view the binary grid file just fine in ArcMAP etc.
Here are the results when i run gdalinfo on the binary grid file. It seems
to be fine
Driver: AIG/Arc/Info Binary Grid
Files: /home/vish/Sample_Data/nh_priority
/home/vish/Sample_Data/nh_priority.ovr
/home/vish/Sample_Data/nh_priority/vat.adf
/home/vish/Sample_Data/nh_priority/w001001x.adf
/home/vish/Sample_Data/nh_priority/w001001.adf
/home/vish/Sample_Data/nh_priority/hdr.adf
/home/vish/Sample_Data/nh_priority/dblbnd.adf
/home/vish/Sample_Data/nh_priority/prj.adf
/home/vish/Sample_Data/nh_priority/sta.adf
Size is 4987, 9645
Coordinate System is:
PROJCS["NAD83 / New Hampshire",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4269"]],
UNIT["METERS",1],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",42.5],
PARAMETER["central_meridian",-71.66666666666667],
PARAMETER["scale_factor",0.999966667],
PARAMETER["false_easting",300000],
PARAMETER["false_northing",0],
AUTHORITY["EPSG","32110"],
AXIS["X",EAST],
AXIS["Y",NORTH]]
Origin = (228040.838957945175935,311318.187724410032388)
Pixel Size = (30.000000000000000,-30.000000000000000)
Corner Coordinates:
Upper Left ( 228040.839, 311318.188) ( 72d35'2.81"W, 45d17'53.85"N)
Lower Left ( 228040.839, 21968.188) ( 72d32'41.44"W, 42d41'39.84"N)
Upper Right ( 377650.839, 311318.188) ( 70d40'35.98"W, 45d17'51.67"N)
Lower Right ( 377650.839, 21968.188) ( 70d43'8.53"W, 42d41'37.85"N)
Center ( 302845.839, 166643.188) ( 71d37'52.26"W, 44d 0'0.06"N)
Band 1 Block=256x16 Type=Byte, ColorInterp=Palette
Min=0.000 Max=2.000
NoData Value=255
Overviews: 2494x4823, 1247x2412, 624x1206, 312x603, 156x302
Color Table (RGB with 3 entries)
0: 255,255,255,255
1: 211,255,190,255
2: 0,84,3,255
<GDALRasterAttributeTable>
<FieldDefn index="0">
<Name>VALUE</Name>
<Type>0</Type>
<Usage>5</Usage>
</FieldDefn>
<FieldDefn index="1">
<Name>COUNT</Name>
<Type>0</Type>
<Usage>1</Usage>
</FieldDefn>
<FieldDefn index="2">
<Name>STEW_STATUS</Name>
<Type>2</Type>
<Usage>0</Usage>
</FieldDefn>
<Row index="0">
<F>0</F>
<F>7209043</F>
<F>non-eligible</F>
</Row>
<Row index="1">
<F>1</F>
<F>7672024</F>
<F>eligible, non-priority</F>
</Row>
<Row index="2">
<F>2</F>
<F>11779591</F>
<F>priority</F>
</Row>
</GDALRasterAttributeTable>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120207/c444c705/attachment.html
