[gdal-dev] Geolocation Arrays ??
Anton Korosov
anton.korosov at nersc.no
Wed Feb 8 03:21:53 EST 2012
Hello Etienne!
I also got such error when trying to process MODIS L1B images taken near
the pole. Try to set some limited extent with the -te option for
gdalwarp. It helped me, at least.
Best regards!
Anton
On 02/07/2012 10:22 PM, Etienne Tourigny wrote:
> Even, Frank,
> thanks for your answers. I have run into a problem with using
> gdalwarp with geoloc transform.
> In ticket #1895 there is an hdf file for which the HDF4 driver creates
> GEOLOCATION metadata.
> Trying gdalwarp on it gives an error, and the result transform is
> incorrect. Am I doing something wrong, or is this a bug?
> command is : gdalwarp -geoloc -t_srs EPSG:4326
> HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":13 tmp1.tif
> more info below:
> $ gdalinfo HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":13
> Driver: HDF4Image/HDF4 Dataset
> Files: A2006005182000.L2_LAC_SST.x.hdf
> Size is 389, 602
> Coordinate System is `'
> Metadata:
> Geolocation:
> LINE_OFFSET=0
> LINE_STEP=1
> PIXEL_OFFSET=0
> PIXEL_STEP=1
> SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
> X_BAND=1
> X_DATASET=HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":11
> Y_BAND=1
> Y_DATASET=HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":12
> Corner Coordinates:
> $ gdalwarp -geoloc -t_srs EPSG:4326
> Creating output file that is 31119P x 5864L.
> Processing input file HDF4_SDS:UNKNOWN:A2006005182000.L2_LAC_SST.x.hdf:13.
> ERROR 1: Too many points (441 out of 441) failed to transform,
> unable to compute output bounds.
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> $ gdalinfo tmp1.tif
> Driver: GTiff/GeoTIFF
> Files: tmp1.tif
> Size is 31119, 5864
> Coordinate System is:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> Origin = (-90.198287963867188,90.300000000000011)
> Pixel Size = (0.015398926739995,-0.015398926739995)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( -90.1982880, 90.3000000) ( 90d11'53.84"W, 90d18' 0.00"N)
> Lower Left ( -90.1982880, 0.0006936) ( 90d11'53.84"W, 0d 0' 2.50"N)
> Upper Right ( 389.001, 90.300) (Invalid angle, 90d18' 0.00"N)
> Lower Right ( 389.001, 0.001) (Invalid angle, 0d 0' 2.50"N)
> Center ( 149.4013126, 45.1503468) (149d24' 4.73"E, 45d 9' 1.25"N)
> Regards,
> Etienne
> On Tue, Feb 7, 2012 at 7:05 PM, Frank Warmerdam<warmerdam at pobox.com> wrote:
>> On Tue, Feb 7, 2012 at 7:40 AM, Etienne Tourigny
>> <etourigny.dev at gmail.com> wrote:
>>> Hi all,
>>> I would like to have information on the status of geolocation array
>>> support in GDAL.
>>> The relevant RFC4 (http://trac.osgeo.org/gdal/wiki/rfc4_geolocate) is
>>> still "under development", and the information there is that
>>> GDALCreateGeoLocTransformer "is currently partially implemented".
>> Etienne,
>> I think the geoloc transformer received some fixes from someone
>> other than myself and now is working reasonable well. It would
>> be desirable to freshen up the RFC and get it passed but it isn't
>> particularly a priority of mine so I'm not likely to drive it in the
>> very near future.
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Software Developer
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
