[gdal-dev] ogr2ogr in python
Alessandro Candini candini at meeo.it
Wed Feb 8 05:25:07 EST 2012
Thanks.
But is it already included in GDAL distribution?
I have version 1.7.2 on my system and I did not found this file in the
whole system...
Maybe I can include that file into my python shared lib direcory such as
/usr/share/pyshared/
>> Does it exist an analogue tool in python?
> Yes, see http://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/ogr2ogr.py
>> Or should I open the file and launch several manipulation functions in
>> order to achieve the same result?
>> Thanks in advance.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Alessandro Candini
MEEO S.r.l.
Via Saragat 9
I-44122 Ferrara, Italy
Tel: +39 0532 1861501
Fax: +39 0532 1861637
http://www.meeo.it
"ATTENZIONE:le informazioni contenute in questo messaggio sono
da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
per errore è tenuto ad informare il mittente ed a rimuoverlo
definitivamente da ogni supporto elettronico o cartaceo."
"WARNING:This message contains confidential and/or proprietary
information which may be subject to privilege or immunity and which
is intended for use of its addressee only. Should you receive this
message in error, you are kindly requested to inform the sender and
to definitively remove it from any paper or electronic format."
