[gdal-dev] ogr2ogr in python
Alessandro Candini candini at meeo.it
Wed Feb 8 05:38:40 EST 2012
You are right: I have put ogr2ogr.py file inside /usr/bin and...
user at office ~ $ ogr2ogr.py
ERROR: Python bindings of GDAL 1.8.0 or later required
The problem is that I cannot update my GDAL version at the moment, it
will mess up all my dependencies and so on...
Is there an alternative?
Maybe with a bunch of GDAL python functions already present in version
1.7.3, I can get the same result...
Any suggestions?
> Selon Alessandro Candini<candini at meeo.it>:
>> Thanks.
>> But is it already included in GDAL distribution?
>> I have version 1.7.2 on my system and I did not found this file in the
>> whole system...
> It is relatively new (perhaps 1.8. don't remember). And anyways it is in the
> sample category that is generally not distributed with binary packages.
>> Maybe I can include that file into my python shared lib direcory such as
>> /usr/share/pyshared/
> You can use it anywhere you like and modify it for your needs.
