[gdal-dev] Does GDAL API for Python use <Scale> and <Offset> in
VRT?
Even Rouault
even.rouault at mines-paris.org
Wed Feb 8 06:01:41 EST 2012
Selon Anton Korosov <anton.korosov at nersc.no>:
> Hello everybody!
> I'm trying to read values from a VRT file in Python. When I modify
> <Scale> or <Offset> it seem not to make any effect.
> I have a simple VRT of a Landsat7 file (below). It has neither scale nor
> offset. I launch the given script twice:
> 1st time to test the value of scale and the value from a band and to
> change the value of scale.
> 2nd time I test value of scale and value from a band. The output shows
> that the scale has changed, but the value is the same. I would expect
> that the second time the value should be 70.
> Does it mean that ReadAsArray() doesn't interpret <Scale> and <Offset>
> tags? Ot do I do (expect) something wrong?
Yes, ReadAsArray() doesn't interpret <Scale> or <Offset>. They are
interpretation hints for the user, but GDAL won't alter the values read from the
dataset.
Alternatively, you can use the -unscale option of gdal_translate so that scale
and offset are taken into account.
> Thank you!
> Anton
> Script:
> l7 = gdal.Open('L71211005_00520100824_B10.vrt')
> print l7.GetRasterBand(1).GetScale()
> print l7.GetRasterBand(1).ReadAsArray()[3000, 3000]
> l7.GetRasterBand(1).SetScale(2)
> l7.FlushCache()
> l7 = None
> Output:
> > python test.py
> 1.0
> 35
> > python test.py
> 2.0
> 35
> VRT-file before test:
> <VRTDataset rasterXSize="9211" rasterYSize="9021">
> <SRS>PROJCS["WGS 84 / UTM zone 33N",GEOGCS["WGS
> 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",15],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32633"]]</SRS>
> <GeoTransform> 3.6178500000000000e+05, 3.0000000000000000e+01,
> 0.0000000000000000e+00, 8.6874150000000000e+06,
> 0.0000000000000000e+00, -3.0000000000000000e+01</GeoTransform>
> <Metadata>
> <MDI key="AREA_OR_POINT">Point</MDI>
> </Metadata>
> <VRTRasterBand dataType="Byte" band="1">
> <Metadata />
> <ColorInterp>Gray</ColorInterp>
> <SimpleSource>
> <SourceFilename
> relativeToVRT="1">L71211005_00520100824_B10.TIF</SourceFilename>
> <SourceBand>1</SourceBand>
> <SourceProperties RasterXSize="9211" RasterYSize="9021"
> DataType="Byte" BlockXSize="9211" BlockYSize="1" />
> <SrcRect xOff="0" yOff="0" xSize="9211" ySize="9021" />
> <DstRect xOff="0" yOff="0" xSize="9211" ySize="9021" />
> </SimpleSource>
> </VRTRasterBand>
> </VRTDataset>
> VRT-file after test:
> <Metadata>
> </Metadata>
> <Metadata />
> <Scale>2</Scale>
> <SimpleSource>
> <SourceFilename
> </SimpleSource>
> </VRTRasterBand>
> </VRTDataset>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
