[gdal-dev] Geolocation Arrays ??
Anton Korosov
anton.korosov at nersc.no
Wed Feb 8 08:19:05 EST 2012
Hi Etienne!
probably yes. At least that's what I got from an answer from Brian some
time ago:
> > EOS_SWATH has 2 geolocation arrays, you might try the -geoloc switch to
> > gdalwarp, otherwise it creates a handfull of gcps from the arrays, if
> > you get a error about points failing to transform, set the output
extent
> > with the -te switch.
> > also you could try the swath2grid application in
> > https://lpdaac.usgs.gov/tools/modis_reprojection_tool_swath
> > Brian
Anton
On 02/08/2012 02:13 PM, Etienne Tourigny wrote:
> Thanks Anton,
> The latitudes of this dataset span from 26.77687 to 33.82318 , so
> nowhere near the poles!
> I tried your suggestion, using the extents from the hdf metadata:
> :Northernmost\ Latitude = 33.82318f ;
> :Southernmost\ Latitude = 26.77687f ;
> :Easternmost\ Longitude = -79.69389f ;
> :Westernmost\ Longitude = -90.15974f ;
> $ gdalwarp -geoloc -t_srs EPSG:4326 -te -90.15974 26.77687 -79.69389
> 33.82318f --debug off
> HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":13 tmp1.tif
> And casual inspection shows that the value is correctly reprojected
> (the outlines of Florida are consistent).
> ==> Does this mean that gdalwarp -geoloc should always be used with -te option?
> Etienne
> On Wed, Feb 8, 2012 at 6:21 AM, Anton Korosov<anton.korosov at nersc.no> wrote:
>> Hello Etienne!
>> I also got such error when trying to process MODIS L1B images taken near the
>> pole. Try to set some limited extent with the -te option for gdalwarp. It
>> helped me, at least.
>> Best regards!
>> Anton
>> On 02/07/2012 10:22 PM, Etienne Tourigny wrote:
>>> Even, Frank,
>>> thanks for your answers. I have run into a problem with using
>>> gdalwarp with geoloc transform.
>>> In ticket #1895 there is an hdf file for which the HDF4 driver creates
>>> GEOLOCATION metadata.
>>> Trying gdalwarp on it gives an error, and the result transform is
>>> incorrect. Am I doing something wrong, or is this a bug?
>>> command is : gdalwarp -geoloc -t_srs EPSG:4326
>>> more info below:
>>> $ gdalinfo HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":13
>>> Driver: HDF4Image/HDF4 Dataset
>>> Files: A2006005182000.L2_LAC_SST.x.hdf
>>> Size is 389, 602
>>> Coordinate System is `'
>>> Metadata:
>>> Geolocation:
>>> LINE_OFFSET=0
>>> LINE_STEP=1
>>> PIXEL_OFFSET=0
>>> PIXEL_STEP=1
>>> SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
>>> X_BAND=1
>>> X_DATASET=HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":11
>>> Y_BAND=1
>>> Y_DATASET=HDF4_SDS:UNKNOWN:"A2006005182000.L2_LAC_SST.x.hdf":12
>>> Corner Coordinates:
>>> Creating output file that is 31119P x 5864L.
>>> Processing input file HDF4_SDS:UNKNOWN:A2006005182000.L2_LAC_SST.x.hdf:13.
>>> ERROR 1: Too many points (441 out of 441) failed to transform,
>>> unable to compute output bounds.
>>> 0...10...20...30...40...50...60...70...80...90...100 - done.
>>> $ gdalinfo tmp1.tif
>>> Driver: GTiff/GeoTIFF
>>> Files: tmp1.tif
>>> Size is 31119, 5864
>>> Coordinate System is:
>>> GEOGCS["WGS 84",
>>> DATUM["WGS_1984",
>>> SPHEROID["WGS 84",6378137,298.257223563,
>>> PRIMEM["Greenwich",0],
>>> UNIT["degree",0.0174532925199433],
>>> Origin = (-90.198287963867188,90.300000000000011)
>>> Pixel Size = (0.015398926739995,-0.015398926739995)
>>> Metadata:
>>> AREA_OR_POINT=Area
>>> Image Structure Metadata:
>>> INTERLEAVE=BAND
>>> Corner Coordinates:
>>> Upper Left ( -90.1982880, 90.3000000) ( 90d11'53.84"W, 90d18' 0.00"N)
>>> Lower Left ( -90.1982880, 0.0006936) ( 90d11'53.84"W, 0d 0' 2.50"N)
>>> Upper Right ( 389.001, 90.300) (Invalid angle, 90d18' 0.00"N)
>>> Lower Right ( 389.001, 0.001) (Invalid angle, 0d 0' 2.50"N)
>>> Center ( 149.4013126, 45.1503468) (149d24' 4.73"E, 45d 9' 1.25"N)
>>> Regards,
>>> Etienne
>>> On Tue, Feb 7, 2012 at 7:05 PM, Frank Warmerdam<warmerdam at pobox.com>
>>> wrote:
>>>> On Tue, Feb 7, 2012 at 7:40 AM, Etienne Tourigny
>>>> <etourigny.dev at gmail.com> wrote:
>>>>> Hi all,
>>>>> I would like to have information on the status of geolocation array
>>>>> support in GDAL.
>>>>> The relevant RFC4 (http://trac.osgeo.org/gdal/wiki/rfc4_geolocate) is
>>>>> still "under development", and the information there is that
>>>>> GDALCreateGeoLocTransformer "is currently partially implemented".
>>>> Etienne,
>>>> I think the geoloc transformer received some fixes from someone
>>>> other than myself and now is working reasonable well. It would
>>>> be desirable to freshen up the RFC and get it passed but it isn't
>>>> particularly a priority of mine so I'm not likely to drive it in the
>>>> very near future.
>>>> Best regards,
>>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>>> and watch the world go round - Rush | Geospatial Software Developer
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
