[gdal-dev] PostGIS SRID conundrum
Martin Chapman
chapmanm at pixia.com
Sat Feb 11 00:48:55 EST 2012
Brent,
Thank you very much for the advice. What I resorted to (at least for the
present) is:
1. I try to get the geogcs or projcs (if projected) authority code
from OGR. If successful, I try to find a match in the spatial_ref_sys
table. If I find a match then I compare the wkt, if it’s exactly the same I
use it. If not I go to number 2.
2. I export the proj4 text from OGR and do a select on the
spatial_ref_sys table for an exact match. If found I use that srid. If not
I go to number 3.
3. I export the wkt text from OGR and do a select on the
I go to number 4.
4. I select the max(srid) where srid > 10000000. If zero is returned
then I use that base number (10000000) and add a new entry to the
spatial_ref_sys table using the proj4 text and wkt so all fields have a
value…and my app name as the authority (makes me feel important J). If a
max above 10000000 is found then I take the max and add one and then add the
new entry.
If you or anyone else can see any flaws in that logic I would appreciate
some criticism.
Thanks again for your feedback!
Best regards,
Martin
From: pcreso at pcreso.com [mailto:pcreso at pcreso.com]
Sent: Friday, February 10, 2012 10:33 PM
To: Martin Chapman
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] PostGIS SRID conundrum
ESRI does not use a SRID, it uses a text string that needs complex parsing
to work. If ESRI supported EPSG codes it would be easier...
The spatial_ref_sys table contains entries for all EPSG recognised
projections. If you have a reasonable case to have a projection inluded by
EPSG, submit a request to EPSG & it will finish up in the Postgis
spatial_reference table.
In the short term, add a proj4txt record for your projection with an
arbitrary new srid in the spatial_ref_sys table & it will work fine in
Postgis. If you want it to work with GDAL/OGR then you;ll need to add it to
the proj4 list of projection parameters. Where this is depends on your OS &
implementation.
See this spec:
http://remotesensing.org/geotiff/proj_list/orthographic.html
The proj4 parameter list for your case may need to specify WGS84 as your
ellipsoid & datum.
HTH,
Brent Wood
--- On Sat, 2/11/12, Martin Chapman <chapmanm at pixia.com> wrote:
Subject: [gdal-dev] PostGIS SRID conundrum
To: gdal-dev at lists.osgeo.org
Date: Saturday, February 11, 2012, 12:25 PM
I know this question isn’t exactly related to GDAL but I thought someone on
the list might be able to answer this question.
So, I have a shape file that has the following spatial reference:
PROJCS["Orthographic",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Orthographic"],PARAMETER["Latitude_Of_Center",40],PARAMETER["Longitude_Of_Center",-75],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["User
Defined",1]]
It was generated using OGR. I want to insert it into postgres / postgis but
there is no direct match for the wkt or proj4 definition in the
spatial_ref_sys table. So, I go to insert it into the table but the
question arises, what SRID do I use? Do I just fudge a random one with a
high enough value that I hope it won’t conflict with some other SRID in the
future, or do I create a table based off of the heterogeneous list of SRIDs
at spatialreference.org and insert from that? I would like to do the later
but that will be a pain unless someone has a put together a batch insert sql
file for all the projections on spatialreference.org. Still, there is
always the possibility that I may run into one that isn’t defined and I will
have to fudge my own number anyway.
Question: What is the best way to handle this? I wish the spatial_ref_sys
table came with all the ESRI and other SRID definitions.
Suggestions are much appreciated!
Best regards,
Martin
-----Inline Attachment Follows-----
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120211/e2e040f6/attachment-0001.html
