[gdal-dev] Problem with GDAL/WMS -> GeoServer/WMS
Even Rouault
even.rouault at mines-paris.org
Sun Feb 12 04:22:51 EST 2012
Le dimanche 12 février 2012 10:05:21, Marian Krivos a écrit :
> Hello,
> I'm trying connect to my fresh installed geoserver with this result:
> $ gdalinfo http://188.123.97.20:6543/geoserver/sf/wms
Try the following (if GDAL >= 1.9.0) :
$ gdalinfo WMS:http://188.123.97.20:6543/geoserver/sf/wms
> ERROR 4: `/vsimem/http_1/wms' not recognised as a supported file format.
> ERROR 4: `/tmp/wms' not recognised as a supported file format.
> gdalinfo failed - unable to open
> 'http://188.123.97.20:6543/geoserver/sf/wms'.
> TCP conversation is:
> GET /geoserver/sf/wms HTTP/1.1
> Host: 188.123.97.20:6543
> Accept: */*
> Accept-Encoding: gzip
> HTTP/1.1 200 OK
> Content-Type: application/xml
> Content-Length: 274
> Content-Encoding: gzip
> Server: Jetty(6.1.8)
> <?xml version="1.0" encoding="UTF-8"?>
> <ows:ExceptionReport version="1.0.0"
> xsi:schemaLocation="http://www.opengis.net/ows
> http://188.123.97.20:6543/geoserver/schemas/ows/1.0.0/owsExceptionReport.xs
> d" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ows="http://www.opengis.net/ows">
> <ows:Exception exceptionCode="NoApplicableCode">
> <ows:ExceptionText>java.lang.NullPointerException
> null</ows:ExceptionText>
> </ows:Exception>
> </ows:ExceptionReport>
> Any ideas?
> Best Regards
> Marian K.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
