[gdal-dev] Unable to open GRIB file
SupportLists
supportlists at qlands.com
Wed Feb 15 03:08:51 EST 2012
As far as I know is a raster.
You can get it from:
http://www.qlands.com/other_files/2011-01.grib
This grib is only one record from the whole file and it contains maximum
temperature for the whole world.
The following is the wgrib ./2011-01.grib -V of the file
rec 1:0:date 2011010100 MX2T kpds5=201 kpds6=1 kpds7=0 levels=(0,0)
grid=255 sfc ECext=1 class=14 type=9 stream=1025 Version=0001 valid 0-3hr:
MX2T=Maximum temperature at 2 metres since previous post-processing [K]
timerange 2 P1 0 P2 3 TimeU 1 nx -1 ny 256 GDS grid 4 num_in_ave 0
missing 0
center 98 subcenter 0 process 128 Table 128 scan: WE:NS winds(N/S)
thinned gaussian: lat 89.462000 to -89.462000
long 0.000000 to 359.296000, 88838 grid pts (-1 x 256) scan
0 mode 0 bdsgrid 1
18 25 36 40 45 50 60 64 72 72 80 90 90
100 108
120 120 125 128 144 144 150 160 160 180 180 180 192
192 200
216 216 216 225 240 240 240 250 250 256 270 270 288
288 288
300 300 320 320 320 320 324 360 360 360 360 360 360
360 375
375 375 375 384 384 400 400 400 400 405 432 432 432
432 432
432 432 450 450 450 450 450 480 480 480 480 480 480
480 480
480 480 486 486 486 500 500 500 500 500 500 500 512
512 512
512 512 512 512 512 512 512 512 512 512 512 512 512
512 512
512 512
512 512
512 512 512 512 500 500 500 500 500 500 500 486 486
486 480
480 480 480 480 480 480 480 480 480 450 450 450 450
450 432
432 432 432 432 432 432 405 400 400 400 400 384 384
375 375
375 375 360 360 360 360 360 360 360 324 320 320 320
320 300
300 288 288 288 270 270 256 250 250 240 240 240 225
216 216
216 200 192 192 180 180 180 160 160 150 144 144 128
125 120
120 108 100 90 90 80 72 72 64 60 50 45 40
36 25
18
min/max data 223.996 316.531 num bits 16 BDS_Ref 223.996 DecScale
0 BinScale -9
Many thanks,
Carlos
On 02/15/2012 10:44 AM, Brian Case wrote:
> On Wed, 2012-02-15 at 09:10 +0300, SupportLists wrote:
> Carlos
> is it raster or vector data?
> can you make the file accessible some place?
> Brian
>> Hi,
>> I am trying to open a grib file (meteorological data) with GDAL 1.8.1
>> but i get the following error:
>> ./2011.grib is a grib file, but no raster dataset was successfully
>> identified.
>> gdalinfo failed - unable to open './2011.grib'
>> Other tools like wgrib successfully opens the same file.
>> Any idea what is wrong?
>> Thanks,
>> Carlos.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120215/0702fb4b/attachment-0001.html
