[gdal-dev] Creating NITF with GCPs
Even Rouault
even.rouault at mines-paris.org
Mon Feb 20 14:56:56 EST 2012
Le lundi 20 février 2012 20:46:22, Livneh Yehiyam a écrit :
> Thanks Even.
> We haven't made the switch to 1.9 yet. I will add it to our 1.8.1. Do you
> see any problems with that?
I don't anticipate huge issues, but the driver has evolved a bit during 1.9
cycle, so the patch won't apply cleanly, I guess
> Sent from my mobile
> From: "Even Rouault"
> Subject: Re: [gdal-dev] Creating NITF with GCPs
> Date: 20 פברואר 2012 21:20
> Le lundi 20 février 2012 17:24:35, Livneh Yehiyam a écrit :
> > Hi
> > I'm trying to write an NITF image where the geo-registration is with 4
> > GCPs. Is this functionality supported by the NITF driver? Looking through
> > the code it seems that there is no way to create the IGEOLO data to the
> > NITF from the supplied GCPs, but rather it will always calculate the
> > IGEOLO data from the affine transform.
> > I'm using GDAL 1.8.1.
> > Am I missing something?
> No, I've just added support for SetGCPs() in trunk in r23997.
> > Thanks
> > Yehiyam Livneh
> > ** ******************* This message (including any attachments) issued by
> > RAFAEL- ADVANCED DEFENSE SYSTEMS LTD. (hereinafter "RAFAEL") contains
> > confidential information intended for a specific individual and purpose,
> > may constitute information that is privileged or confidential or
> > otherwise protected from disclosure. If you are not the intended
> > recipient, you should contact us immediately and thereafter delete this
> > message from your system. You are hereby notified that any disclosure,
> > copying,
> > dissemination, distribution or forwarding of this message, or the taking
> > of any action based on it, is strictly prohibited. If you have received
> > this e-mail in error, please notify us immediately by e-mail
> > mailto:lawraf at rafael.co.il and completely delete or destroy any and all
> > electronic or other copies of the original message and any attachments
> > thereof.
> may constitute information that is privileged or confidential or otherwise
> protected from disclosure. If you are not the intended recipient, you
> should contact us immediately and thereafter delete this message from your
> system. You are hereby notified that any disclosure, copying,
> thereof.
