[gdal-dev] Hillshade + Topographic Map??
TJMartin
tjmgis at gmail.com
Tue Feb 21 05:01:53 EST 2012
Hi
I have managed to create a hillshade using gdaldem and I have my original
topographic rasters. However I do not want the standard grey hillshad or
apply a colour ramp.
Is there a way to combine the hillshade and topo map together - ie add a
transparency or opacity to the hillshade.
I have looked at Photopshop and ImageMagik but the results are then not
supported in QGIS etc
After a trawl through the web the only entry is an ArGIS 10 tutorial
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009t000001v1000000
Hopefully that will explain what I would like to achieve
thanks for anyones help
Tim
View this message in context: http://osgeo-org.1560.n6.nabble.com/Hillshade-Topographic-Map-tp4490698p4490698.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
