[gdal-dev] gdalwarp extent issues
Joaquim Luis
jluis at ualg.pt
Wed Feb 22 09:50:09 EST 2012
On 22-02-2012 00:54, Jay L. wrote:
> List,
> I am attempting to reproject 8 gtiffs, each in a local equirectangular
> projection, back to gcs for use in geoserver. I immediately went to
> gdalwarp to perform this task and am having an issue. The input files
> are stored in positive longitude, while the output SRS is in negative
> longitude. The "shift" to negative longitude is a primary reason for
> wishing to perform the warp.
> The input images which cover 0-90 north and 0-90 south are warping
> correctly. The others are not.
> The other warped output images have an extent of -180 180, when the
> should cover 90 degrees. The images which remain in positive
> longitude are drawing correctly, but have the remained of the extent
> filled in black. Meaning the image which spans 90-180n and 90-180s
> renders, but has an extent of -180 to 180. The input image which are
> shifted to negative longitude have a global extent and
> are completely black.
Jay,
I crossed what seams to be the same problem a couple of days ago and
opened this ticket
http://trac.osgeo.org/gdal/ticket/4523
With a bit more of experimenting after that report I found that the, at
least with global grids, the problem is when they span [0 360]. If they
are in [-180 180] gdalwarp works fine.
if you are interested, I have one Mirone solution to warp from [0 360]
to [-180 180].
Joaquim
> I have tried the following without success:
> gdalwarp -t_srs moon2000.prf input output_warped.tif
> gdalwarp -s_srs <copy of the gdalinfo srs information in a prf> -t_srs
> moon2000.prf input.tif output.tif
> gdalwarp -t_srs moon2000.prf -te <desired extent as xmin ymin xmax
> ymax> input.tif output.tif
> Where moon2000.prf is:
> GEOGCS["Moon 2000",
> DATUM["D_Moon_2000",
> SPHEROID["Moon_2000_IAU_IAG",1737400.0,0.0]],
> PRIMEM["Greenwich",0],
> UNIT["Decimal_Degree",0.0174532925199433]]
> Any insight would be greatly appreciated.
> Jay
> Here is the projection info as output by gdalinfo:
> Coordinate System is:
> PROJCS["EQUIRECTANGULAR MOON",
> GEOGCS["GCS_MOON",
> DATUM["D_MOON",
> SPHEROID["MOON_localRadius",1737400,0]],
> PRIMEM["Reference_Meridian",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Equirectangular"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",0],
> PARAMETER["standard_parallel_1",0],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]]]
> Origin = (100.000000000000000,1819400.000000000000000)
> Pixel Size = (100.000000000000000,-100.000000000000000)
> The coordinate information:
> Corner Coordinates:
> Upper Left ( 100.000, 1819400.000) ( 0d 0'11.87"E, 59d59'59.88"N)
> Lower Left ( 100.000, -100.000) ( 0d 0'11.87"E, 0d 0'11.87"S)
> Upper Right ( 2729200.000, 1819400.000) ( 90d 0'11.69"E, 59d59'59.88"N)
> Lower Right ( 2729200.000, -100.000) ( 90d 0'11.69"E, 0d 0'11.87"S)
> Center ( 1364650.000, 909650.000) ( 45d 0'11.78"E, 29d59'54.00"N)
> Oddly the central meridian and standard_parallel_1 parameters do not
> change with each input file. Since I know that gdal can see the s_srs
> from within the files I have tried using:
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120222/4fe4e0bc/attachment-0001.html
