[gdal-dev] SetSpatialFilter
Ethan Alpert
ealpert at digitalglobe.com
Wed Feb 22 18:31:55 EST 2012
Is it still true that the geometry used for SetSpatialFilter must have
the same CRS as the layer?
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120222/db579ba7/attachment.html
