[gdal-dev] Building GDAL with FileGDB support
Stuart Edwards
sedwards2 at cinci.rr.com
Wed Feb 22 22:23:50 EST 2012
Hi -
I am trying to build GDAL with FileGDB support on Ubuntu 10.4 using the recipe on the GDAL wiki. I have installed GDAL 1.9.0 in /usr/local/ and have placed FileGDB_API from the ArcGIS resource center at /usr/local. Configure --with-fgdb produces a config summary that shows 'yes' for 'with fgdb support'. However, after 'make' and 'make install', the tests for ogrinfo fail - no FileGDB format is acknowledged. I have put the FileGDB_API directory in the GDAL_DRIVER_PATH.
Any ideas on what I may have done incorrectly would be much appreciated.
thx
Stu
