[gdal-dev] drawing line using OGR and mysql in mapserver
Murat Beyhan
beyhan at deprem.gov.tr
Tue Feb 28 02:19:37 EST 2012
Chaitanya,
Map file which is try to draw line as follows
are there any problem on the code
LAYER
NAME sfault1
CONNECTIONTYPE OGR
CONNECTION '<OGRVRTDataSource>
<OGRVRTLayer name="lineview">
<SrcDataSource>MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306,tables=lineview</SrcDataSource>
<SrcLayer>lineview</SrcLayer>
<GeometryType>wkbLineString</GeometryType>
<GeometryField encoding="WKT" field="geom"/>
<LayerSRS>WGS84</LayerSRS>
<FID>eq_id</FID>
</OGRVRTLayer>
</OGRVRTDataSource>'
DATA sfault1
STATUS on
TYPE line
CLASS
NAME "Source Fault"
SYMBOL "cline"
SIZE 3
COLOR 0 0 255
END
END
ogrinfo
sfault -summary
INFO: Open of
`MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306'
using driver `MySQL' successful.
Layer name: sfault
Geometry: None
Feature Count: 1
Layer SRS WKT:
(unknown)
eq_id: String (14.0)
lat1: Real (7.4)
lon1: Real (7.4)
lat2: Real (7.4)
lon2: Real (7.4)
**************linewiew created by following sql statement:*************
create view lineview as select eq_id, "LINESTRING(" + lon1 + " " + lat1
+ "," + lon2 + " " + lat2 + ")" as geom from sfault
then
[murat at localhost ~]$ ogrinfo
lineview -summary
INFO: Open of
Layer name: lineview
Geometry: None
Feature Count: 1
Layer SRS WKT:
(unknown)
geom: Real (0.0)
as you see there is no problem to connect mysql and read information
created mysql geometries from shape file also works here is an example
MYSQL:testogr,user=root,password=mysqlpasswd,host=localhost,port=3306
iller -summary
INFO: Open of
`MYSQL:testogr,user=root,password=mysqlpasswd,host=localhost,port=3306'
successful.
Layer name: iller
Geometry: Polygon
Feature Count: 83
Extent: (26.026489, 35.820221) - (44.869179, 42.094917)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS_1984",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.0174532925199433]]
FID Column = OGR_FID
Geometry Column = SHAPE2
area: Real (13.6)
perimeter: Real (13.6)
illerdd_: Real (0.0)
illerdd_id: Real (0.0)
il_kod: Real (2.0)
iladi: String (20.0)
Now I would like to learn what is wrong with my procedures... please
help
Murat
On Tue, 2012-02-28 at 09:03 +0530, Chaitanya kumar CH wrote:
> Murat,
> Since it is MySQL it doesn't matter much how you store it. If you are
> going to edit the end points later, storing them as points is
> preferable, otherwise store them as wkt linestring geometries.
> For your mapfile, first check if the extents are correct. Then check
> if the mapfile works with a shapefile created from the geometries in
> MySQL.
> On Tuesday, February 28, 2012, Murat BEYHAN wrote:
> Chaitanya,
> thanks for your repply,
> Actually I use ogr and mysql to draw point for example
> epicenter of
> earthquakes. But this is the first time to draw line which is
> stored in
> Mysql as a table. Actually there is no problem on drawing
> shape file of the
> line. But I would like to draw it using MySql and ogr
> functionality. So I
> have only start and end point of line and I store it on MySql
> database then
> I try to draw it considering id of the line by sql statement.
> Just I would lie to learn how to code it on Mapserver map file
> and how
> should I store line on database as a start and stop point of
> the line or as
> a geometry . Please help...
> thanks
> On Mon, 27 Feb 2012 22:09:52 +0530, Chaitanya kumar CH wrote
> > Murat,
> > First check if your database is accessible using ogrinfo[1].
> > Then create a vrt file with the content you specified in the
> CONNECTION
> > field of the mapfile. Check if ogrinfo gives expected
> results with this
> > file.
> > You probably have gdal executables if you are running
> mapserver.
> > [1]: http://www.gdal.org/ogrinfo.html
> > On Mon, Feb 27, 2012 at 12:48 PM, Murat Beyhan
> > <beyhan at deprem.gov.tr> wrote:
> > > Dear all,
> > > I have shared this mail on Mapserver list but could not
> solve my
> > > problem.
> > > Still could not achieve to draw line using start and stop
> point line
> > > data stored in MySql database.
> > > I have tried Mr. Robert's solution but I have faced an
> error message.
> > > in map file
> > > I changed Geometrytype from wkbline to wkblinestring.
> > > LAYER
> > > NAME sfault1
> > > CONNECTIONTYPE OGR
> > > <FID>eq_id</FID>
> > > </OGRVRTLayer>
> > > DATA sfault1
> > > STATUS on
> > > TYPE line
> > > CLASS
> > > NAME "Source Fault"
> > > SYMBOL "cline"
> > > SIZE 3
> > > COLOR 0 0 255
> > > END
> > > END
> > > in database
> > > I have two table
> > > one is sfault which store
> > > id lat1 lon1 lat2 lon2
> > > and another is lineview which is a view
> > > of this table created by following
> + " " + lat1
> > > there is an another issue,
> > > I have to draw line by considering id
> > > so in the map When I select one id, line should be belong
> to this id's
> > > information
> > > so I have to make a sql statement as follow instead of
> draw all line
> > > stored in database I have to draw just one line
> considering id
> > > something like this:
> > > select eq_id, geom from lineview where id like '%id%'
> > > please help about this subject....
> > > Regards....
> > > Murat
> > > This message has been scanned for viruses and
> > > dangerous content by MailScanner, and is
> > > believed to be clean.
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Best regards,
> > Chaitanya kumar CH.
> > +91-9494447584
> > 17.2416N 80.1426E
> Murat Beyhan
> Jeofizik Yük. Müh.
> T.C.
> BAŞBAKANLIK
> Afet ve Acil Durum Yönetimi Başkanlığı
> Deprem Dairesi Başkanlığı
> Eskişehir Yolu 12. Km. Lodumlu/Ankara
> Tel:+90 (312) 2872680-1550
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
Murat BEYHAN
Jeofizik Y.Müh.
T.C. Başbakanlık
Lodumlu/ANKARA
Tel: 312 2872680-1556
email:beyhan at deprem.gov.tr
