[gdal-dev] reading NOAA-19 AVHRR
Even Rouault even.rouault at mines-paris.org
Tue Feb 28 11:06:05 EST 2012
Knut-Frode,
I've skimmed quickly through the driver code and if you are lucky, it is
probably just a matter of changing a few lines (well, I can be wrong).
If you have a debug build of GDAL, you can first try to run "gdalinfo --debug on
avhrr_20120227_235800_noaa19.hrp" . My guess (based on
http://en.wikipedia.org/wiki/NOAA-19 saying that NOAA-19 = NOAA-N' and NOOA-N'
appearing in commented code of the driver...) would be that you would see :
"Unknown spacecraft ID "8"".
If so, you could test the following patch :
Index: l1bdataset.cpp
--- l1bdataset.cpp	(revision 24036)
+++ l1bdataset.cpp	(working copy)
@@ -61,6 +61,7 @@
     NOAA16,     // NOAA-16(L)
     NOAA17,     // NOAA-17(M)
     NOAA18,     // NOAA-18(N)
+    NOAA19,     // NOAA-19(N')
     METOP2      // METOP-2(A)
@@ -1025,10 +1026,10 @@
             case 7:
                 eSpacecraftID = NOAA18;
                 break;
-            /* FIXME: find appropriate samples and test these two cases:
-             * case 8:
-                eSpacecraftID = NOAA-N';
+            case 8:
+                eSpacecraftID = NOAA19;
                 break;
+            /* FIXME: find appropriate samples and test that case:
             case 11:
                 eSpacecraftID = METOP-1;
                 break;*/
@@ -1155,6 +1156,9 @@
         case NOAA18:
             pszText = "NOAA-18(N)";
             break;
+        case NOAA19:
+            pszText = "NOAA-19(N')";
+            break;
         case METOP2:
             pszText = "METOP-2(A)";
             break;
Perhaps Andrey Kiselev, the author of the driver, would have better clues.
Best regards,
Even
