[gdal-dev] drawing line using OGR and mysql in mapserver
Chaitanya kumar CH
chaitanya.ch at gmail.com
Wed Feb 29 22:52:46 EST 2012
Murat,
You should check MySQL's SQL syntax to concatenate strings and decimals to
produce a string.
On Wednesday, February 29, 2012, Murat Beyhan <beyhan at deprem.gov.tr> wrote:
> Chaitanya,
> here is the structure of table on database
> sfault :
> eq_id varchar(14)
> lat1 decimal(7,4)
> lon1 decimal(7,4)
> lat2 decimal(7,4)
> lon2 decimal(7,4)
> lineview :
> eq_id varchar(14)
> geom double
> it seams geom as double
> I thing it should be geometry isn't it?
> may be I have to change structure of lineview by changing following
> Roberts' suggestion to create view on database
> create view lineview as select eq_id, "LINESTRING(" + lon1 + " " + lat1
> + "," + lon2 + " " + lat2 + ")" as geom from sfault
> but I'm not sure for the line.
> VTR for points, I have tested and works well
> but for line still could not achieved yet, please give me another idea.
> here is test.vrt file
> <OGRVRTDataSource>
> <OGRVRTLayer name="sta">
<SrcDataSource>MYSQL:stations,user=root,password=mysql_passwd,host=localhost,port=3306,tables=sta</SrcDataSource>
> <SrcSQL>SELECT sta_id as name,type,latitude,longitude from sta where
> type like "%SMACH%"</SrcSQL>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="longitude" y="latitude"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> and following code gives successful result as you see
> ogrinfo -ro -al test.vrt
> INFO: Open of `test.vrt' using driver `VRT' successful.
> Layer name: sta
> Geometry: Point
> Feature Count: 12
> Layer SRS WKT:
> (unknown)
> type: String (24.0)
> latitude: Real (5.4)
> longitude: Real (5.4)
> OGRFeature(sta):0
> name (String) = 0617
> type (String) = SMACH
> latitude (Real) = 40.4569
> longitude (Real) = 32.6319
> POINT (32.631900000000002 40.456899999999997)
> OGRFeature(sta):1
> name (String) = 0618
> latitude (Real) = 40.4798
> longitude (Real) = 32.4555
> POINT (32.4555 40.479799999999997)
> As you see this works well.
> I hope you can catch point what is wrong or lack of on my works....
> Thanks again
> On Tue, 2012-02-28 at 18:08 +0530, Chaitanya kumar CH wrote:
>> Murat,
>> I see that your view, lineview, doesn't give the expected geometry
>> type with ogrinfo. It is showing the datatype as Real. Check if the
>> datatype of geom is actually string/text.
>> On Tue, Feb 28, 2012 at 12:49 PM, Murat Beyhan <beyhan at deprem.gov.tr>
>> wrote:
>> Chaitanya,
>> Map file which is try to draw line as follows
>> are there any problem on the code
>> LAYER
>> NAME sfault1
>> CONNECTIONTYPE OGR
>> CONNECTION '<OGRVRTDataSource>
>> <OGRVRTLayer name="lineview">
<SrcDataSource>MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306,tables=lineview</SrcDataSource>
>> <SrcLayer>lineview</SrcLayer>
>> <GeometryType>wkbLineString</GeometryType>
>> <GeometryField encoding="WKT" field="geom"/>
>> <LayerSRS>WGS84</LayerSRS>
>> <FID>eq_id</FID>
>> </OGRVRTLayer>
>> </OGRVRTDataSource>'
>> DATA sfault1
>> STATUS on
>> TYPE line
>> CLASS
>> NAME "Source Fault"
>> SYMBOL "cline"
>> SIZE 3
>> COLOR 0 0 255
>> END
>> END
>> ogrinfo
>> sfault -summary
>> INFO: Open of
`MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306'
>> using driver `MySQL' successful.
>> Layer name: sfault
>> Geometry: None
>> Feature Count: 1
>> Layer SRS WKT:
>> (unknown)
>> eq_id: String (14.0)
>> lat1: Real (7.4)
>> lon1: Real (7.4)
>> lat2: Real (7.4)
>> lon2: Real (7.4)
>> **************linewiew created by following sql
>> statement:*************
>> " " + lat1
>> then
>> [murat at localhost ~]$ ogrinfo
>> lineview -summary
>> INFO: Open of
>> Layer name: lineview
>> Geometry: None
>> Feature Count: 1
>> Layer SRS WKT:
>> (unknown)
>> geom: Real (0.0)
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120301/fa38539d/attachment.html
