[gdal-dev] C# bindings - setting up progress delegate for
Gdal.Open()
Even Rouault
even.rouault at mines-paris.org
Tue Jan 3 05:49:46 EST 2012
Selon Maksim Sestic <max at geoinova.com>:
> Hi all,
> Is there a way to set progress delegate function during a call to
> Gdal.Open()? I'm opening a WMS dataset and I need some sort of progress
> metering during the process, but I don't see a way to attach handler
> function for:
> Dim ds As Dataset = Gdal.Open("<GDAL_WMS>...</GDAL_WMS>",
> Access.GA_ReadOnly)
No, there's no progress callback available for the Open() call. For WMS, the
time is essentially spend in waiting for the response to the GetCapabilities().
So even if there was a mechanism, there would be no way to know the percentage
of completion before the server sends the size of the answser XML, but once you
know it, as it is small, it is almost instantaneously downloaded.
> Regards,
> Maksim Sestic
http://osgeo-org.1803224.n2.nabble.com/C-bindings-setting-up-progress-delegate-for-Gdal-Open-tp7146342p7146342.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
