[gdal-dev] Motion: Promote GDAL 1.9.0RC1 as GDAL 1.9.0 Final
Etienne Tourigny
etourigny.dev at gmail.com
Wed Jan 4 17:23:53 EST 2012
William,
I have created the following ticket, please add any information there,
especially the patch to configure. I will see how to resolve that
issue on linux also.
http://trac.osgeo.org/gdal/ticket/4424
The CF compliance checks (in netcdf_cf.py) can be skipped safely and
are optional, no need to install the cfchecker. The important tests
are in netcdf.py which deal with netcdf-4.
thanks,
Etienne
On Wed, Jan 4, 2012 at 12:46 AM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> OK, looking good, after patching configure to work around netcdf problems mentioned.
> Autotests generally OK. Netcdf tests OK, except I need to install cfchecker to check CF compliance.
> There are a bunch of new tiff_srs_* tests, many that fail. It's dropping some TOWGS84 options, or some AUTHORITY options for PRIMEM and UNIT, or have having precision problems (ie 298.3 becomes 298.2999999999985). Probably a problem with my libgeotiff, other srs tests are fine.
> On Jan 3, 2012, at 8:46 PM, William Kyngesburye wrote:
>> OK, I have NetCDF now with HDF4/5 & DAP. Now configure problems again (again, netcdf is static library, as are HDF4, HDF5 and DAP):
>> My netcdf needs curl (it defaults to using curl), but GDAL doesn't test netcdf with that (curl is tested much later).
>> Netcdf4 also needs some symbols from libhdf5_hl, but this is not checked for.
>> On Jan 3, 2012, at 4:49 PM, Etienne Tourigny wrote:
>>> Folks,
>>> I would appreciate minimal testing for netcdf-4 in osx before
>>> releasing rc2 (which should take a few days at the most).
>>> Wiliam:
>>> The driver in 1.9 includes support for netcdf-4, which uses hdf5 for
>>> storage and supports deflate compression as well as a new data model.
>>> Other important bugfixes and support for CF-1.5 have been included as
>>> well.There are also some new autotests that are skipped if netcdf-4 is
>>> not available to GDAL, if these pass the build should be fine.
>>> On Tue, Jan 3, 2012 at 11:47 AM, William Kyngesburye
>>>> I've always built netcdf without v4 API because GDAL didn't support it. I missed that addition in GDAL 1.9, so it looks like I have more work for compilation and testing ;)
>>>> I saw some time ago that HDF5 added some capbility for integration with netcdf4, GDAL 1.9 supports this now?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
> - the wisdom of Tarzan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
