[gdal-dev] Reading OGRStyle information using C++
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Jan 5 07:21:14 EST 2012
Aneesh,
I don't know if the DXF format maintains a default style or a style table
but OGR's DXF driver doesn't support layer's style table.
On Thu, Jan 5, 2012 at 5:30 PM, Aneesh Muralidharan <symonando at gmail.com>wrote:
> Hi Chaithanya,
> Thanks for the quick reply
> About the style table, I did try to use the layer style table, but I'm
> getting an empty table :(
> By the way I'm trying to read a simple DXF file.
> On Thu, Jan 5, 2012 at 4:57 PM, Chaitanya kumar CH <chaitanya.ch at gmail.com
> > wrote:
>> A layer's style table can be accessed using OGRLayer::GetStyleTable() [1].
>> [1]: http://www.gdal.org/ogr/classOGRLayer.html
>> On Thu, Jan 5, 2012 at 4:55 PM, Chaitanya kumar CH <
>> chaitanya.ch at gmail.com> wrote:
>>> Aneesh,
>>> A layer can have a style table that stores a set of styles that can be
>>> referred by individual features. Usually the style table has a default
>>> style.
>>> Its usage is explained in the same page as the OGR Feature Style
>>> Specification.
>>> On Thu, Jan 5, 2012 at 3:45 PM, Aneesh Muralidharan <symonando at gmail.com
>>> > wrote:
>>>> Hi,
>>>> I'm new to OGR/GDAL and I'm trying to read style information of vectors
>>>> using the OGR C++ API. I followed the documentation available here
>>>> http://www.gdal.org/ogr/ogr_feature_style.html. I have managed to get
>>>> the pen information of the glyphs' in vector file successfully.
>>>> The problem is that, it is unclear that from where can I figure out the
>>>> layer style specification. i.e the global style for the layer ( assuming
>>>> each glyph's pen can be either one of its own or dependent on the layer ).
>>>> The OGRFeatureDefn for the OGRLayer doesn't seem to have this information.
>>>> Also is there any detailed explanation of the API somewhere with some
>>>> sample code snippets ? (for the feature-style api. For read/write I know
>>>> there is http://www.gdal.org/ogr/ogr_apitut.html)
>>>> Hoping for a quick response
>>>> Thanks and regards,
>>>> Aneesh Muralidharan
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Best regards,
>>> Chaitanya kumar CH.
>>> +91-9494447584
>>> 17.2416N 80.1426E
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120105/965ea607/attachment-0001.html
