[gdal-dev] Compiling fails on Debian
Even Rouault even.rouault at mines-paris.org
Mon Jan 9 07:44:22 EST 2012
Frank,
This looks like if the linking of the GDAL shared library was using the static
version of libstdc++ (the message "recompile with -fPIC" is for libstdc++, not
GDAL...) . A bit of googling shows that this error has been encountered with
various software packages.
Several tracks :
1) https://bugs.archlinux.org/task/14268 suggest to check that there is no
/usr/lib/libstdc++.la around. If there's one, rename it, and try again.
2) Other links would suggest that
/usr/lib/gcc/x86_64-linux-gnu/4.4.5/libstdc++.a library was incorrectly built,
and not appropriate for being used by shared libraries.
3) http://code.google.com/p/staff/issues/detail?id=150 is also interesting :
> Very strange, but why g++ tries to link libstdc++ staticaly?
That was the key question.
With the help of strace (my favorite tool) I figured out that g++ fell back to
the static lib (/usr/lib/gcc/x86_64-linux-gnu/4.4.5/libstdc++.a) after getting
an error when trying to access the shared lib
(/usr/lib/gcc/x86_64-linux-gnu/4.4.5/libstdc++.so). The shared lib was a broken
symlink. The link apparently broke when I upgraded libstdc++6 to 4.6.1-4 without
upgrading libstdc++6-4.4-dev at the same time.
Sorry to have bothered you with this...
So perhaps start by upgrading your libstdc++6-4.4-dev package ?
4) If none of the above works and it is libtool related as the above would
suggest, perhaps you could also try adding --without-libtool to your GDAL
./configure command line. The experience shows that it sometimes helps, but I'm
not positive it will be the case here.
> Hi,
> I try to compile gdal 1.9.0RC2 on my Debian machine
> brfr at devel:~/gdal$ uname -ra
> Linux devel 2.6.32-5-amd64 #1 SMP Mon Oct 3 03:59:20 UTC 2011 x86_64
> GNU/Linux
> but make exits with an error 2. The last messages before exiting:
> /usr/bin/ld:
> /usr/lib/gcc/x86_64-linux-gnu/4.4.5/libstdc++.a(functexcept.o):
> relocation R_X86_64_32 against `std::bad_typeid::~bad_typeid()' can not
> be used when making a shared object; recompile with -fPIC
> /usr/lib/gcc/x86_64-linux-gnu/4.4.5/libstdc++.a: could not read symbols:
> Bad value
> collect2: ld returned 1 exit status
> make[1]: *** [libgdal.la] Fehler 1
> make[1]: Leaving directory `/home/brfr/gdal/gdal-1.9.0'
> make: *** [check-lib] Fehler 2
> I tried already with the fPIC flag
> brfr at devel:~/gdal$ export CXXFLAGS="-fPIC"
> brfr at devel:~/gdal$ ./configure --with-python --with-geos=yes --enable-debug
> brfr at devel:~/gdal$ make
> but without success
> Any hints?
> Frank
> Frank BRONIEWSKI
> METRICO s.à r.l.
> géomètres
> technologies d'information géographique
> rue des Romains 36
> L-5433 NIEDERDONVEN
> tél.: +352 26 74 94 - 28
> fax.: +352 26 74 94 99
> http://www.metrico.lu
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
