[gdal-dev] Mismatched output from listgeo/gdalwarp/cs2cs
Pepijn Van Eeckhoudt pepijn at vaneeckhoudt.net
Mon Jan 9 08:24:42 EST 2012
My issue is related to gdal, libgeotiff and proj.4, but the problem
appeared with gdalwarp so I'm posting here. I'm seeing different output
from the various tools that I can't really make sense of and I was
hoping someone here could clarify the meaning of the various output values.
I received a geotiff file from one of my clients that essentially has
all it's referencing metadata set to 'User-Defined'. Listgeo -proj4
prints out:
+proj=tmerc +lat_0=0.000000000 +lon_0=15.000000000 +k=0.999900 +x_0=500000.000 +y_0=-5000000.000 +a=6377397.155 +b=6356078.963 +units=m
I've double checked the geotiff data manually and this is indeed the
information that is in the file. Transverse mercator projection with
respect to the Bessel 1841 ellipsoid in other words. My client
reprojected the geotiff to WGS84 using the following gdalwarp input
./gdalwarp.exe -t_srs '+proj=tmerc +lat_0=0 +lon_0=15 +datum=WGS84'
He then loaded both geotiffs in our GIS tool (not based on osgeo
libraries) and noticed a substantial horizontal shift between the two
variants of the file. I'm now trying to figure out what is going wrong.
I listed what I've been able to find out so far below.
Listgeo prints out the following information for the upper left corner
point:
Upper Left    (  439702.628,   71450.647)  ( 14d13'27.94"E, 45d47' 5.72"N)
If I then take the same projected coordinate and input those into cs2cs
I get different lon lat values.
cs2cs +proj=tmerc +lat_0=0.000000000 +lon_0=15.000000000 +k=0.999900 +x_0=500000.000 +y_0=-5000000.000 +a=6377397.155 +b=6356078.963 +units=m
14d13'59.5"E    45d8'31.057"N 0.000, 71450.647
Shouldn't I be getting the same values here? If not, then what are the
two tools actually showing me; it's not clear to me with respect to
which datum the lon/lat coordinates are defined?
I then tried to get cs2cs to produce WGS84 lat/lon coordinates, but
oddly enough that produced the same output as the previous command.
cs2cs +proj=tmerc +lat_0=0.000000000 +lon_0=15.000000000 +k=0.999900 +x_0=500000.000 +y_0=-5000000.000 +a=6377397.155 +b=6356078.963 +units=m +to +proj=latlon +datum=WGS84 coords.txt
I was able to get different output by adding an explicit +towgs84
parameter for the input CRS
cs2cs +proj=tmerc +lat_0=0.000000000 +lon_0=15.000000000 +k=0.999900 +x_0=500000.000 +y_0=-5000000.000 +a=6377397.155 +b=6356078.963 +units=m +towgs84=0,0,0 +to +proj=latlon +datum=WGS84 coords.txt
14d13'59.5"E    45d8'33.211"N -706.488, 71450.647
This leads me to conclude that without an +datum reference or a +towgs84
parameter value proj (and possibly gdalwarp) no longer performs any
datum transformation whatsoever. In other words it is not converting
from one ellipsoid to the other via geocentric. Is that correct? If so,
what is the rationale behind this choice? Our GIS toolkit takes a
different approach and defaults to +towgs84=0,0,0 instead. My hunch is
that this difference in default interpretation is the cause of the
horizontal shift I'm seeing.
Thanks in advance for any help,
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120109/d1ceef2e/attachment.html
