[gdal-dev] Are these WFS issues worth filing tickets?
Even Rouault
even.rouault at mines-paris.org
Mon Jan 9 16:36:30 EST 2012
> > I don't want to deny there is a problem when issuing ogrinfo, but I'm not
> > sure that setting a default MAXFEATURES on client side is appropriate.
> > The issue is more with GetExtent() and the fact that the reported extent
> > in GetCapabilities is reported as WGS84 and not in the default SRS, or
> > that the values are sometimes junk.
> Sure they are often junk but doing getFeature is an expensive way for
> getting the correct information. Ald also this result may be unreliable if
> it is interpreted to describe the whole WFS feature type it getFeature
> request hits the server side maxFeatures limit. In this case ogrinfo can
> only report the extents of the first [maxFeatures] of the feature type.
> How about having an option -TRUST_GETCAPABILITIES=TRUE and use it as
> a default value? So number of feature could be examined with
> resulttype=hits and extents could be taken as they are in the
> getCapabilities. Or perhaps they could be reported as unknown if
> reprojecting the lat/lon bounding box feels bad or is
> inaccurate/impossible? Extents are not always so interesting.
I also somehow imagined that. Perhaps you could file a ticket about that, so it
can be eventually considered later.
> What do you get with these two requests (check layer info - download and
> convert to shapefile) against this small WFS feature type?
> ogrinfo WFS:http://hip.latuviitta.org/cgi-bin/tinyows municipalities
> ogr2ogr -f "ESRI Shapefile" test.shp WFS:http://hip.latuviitta.org/cgi-bin
> I can see that for me with a Windows laptop two sets of requests are sent.
I just get one GetFeature for each command line as expected. Did you expect
caching between ogrinfo and ogr2ogr ? The caching is just for one OGR session
"of course".
$ ogrinfo WFS:http://hip.latuviitta.org/cgi-bin/tinyows municipalities --debug
on
WFS: http://hip.latuviitta.org/cgi-
bin/tinyows?SERVICE=WFS&REQUEST=GetCapabilities&ACCEPTVERSIONS=1.1.0,1.0.0
HTTP: Fetch(http://hip.latuviitta.org/cgi-
bin/tinyows?SERVICE=WFS&REQUEST=GetCapabilities&ACCEPTVERSIONS=1.1.0,1.0.0)
WFS: GetFeature operation supports hits
WFS: Transaction support !
OGR: OGROpen(WFS:http://hip.latuviitta.org/cgi-bin/tinyows/0x94ac60) succeeded
as WFS.
INFO: Open of `WFS:http://hip.latuviitta.org/cgi-bin/tinyows'
using driver `WFS' successful.
OGR: GetLayerCount() = 55
bin/tinyows?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=lv:municipalities,lv:mml_kunta10k_2011_l,lv:mml_kunta10k_2011_p,lv:mml_kunta100k_2011_l,lv:mml_kunta100k_2011_p,lv:mml_kunta250k_2011_l,lv:mml_kunta250k_2011_p,lv:mml_kunta1000k_2011_l,lv:mml_kunta1000k_2011_p,lv:mml_kunta4500k_2011_l,lv:mml_kunta4500k_2011_p,lv:mml_airport,lv:mml_asemat,lv:mml_avi1_l,lv:mml_avi1_p,lv:mml_cityp,lv:mml_coast_l,lv:mml_coast_p,lv:mml_dcont_l,lv:mml_dcont_p,lv:mml_forest,lv:mml_hcont_l,lv:mml_hcont_p,lv:mml_hpoint,lv:mml_kunta1_l,lv:mml_kunta1_p,lv:mml_kunta1_maa_alue,lv:mml_lake_l,lv:mml_lake_p,lv:mml_maaku1_l,lv:mml_maaku1_p,lv:mml_namep,lv:mml_pelto,lv:mml_railway,lv:mml_river,lv:mml_rivera_l,lv:mml_rivera_p,lv:mml_road,lv:mml_suot,lv:mml_taajama,lv:mml_paikannimet20,lv:peltolohkot_2011,lv:pks_pienalue,lv:pks_suuralue,lv:pks_tilastoalue,lv:pks_pienalue_piste,lv:pks_suuralue_piste,lv:pks_tilastoalue_piste,lv:natura2000_suomi_2010)
Layer name: lv:municipalities
Geometry: Multi Polygon
bin/tinyows?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=lv:municipalities&RESULTTYPE=hits
bin/tinyows?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=lv:municipalities&RESULTTYPE=hits)
Feature Count: 343
bin/tinyows?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=lv:municipalities)
GML: Using Expat reader
OGR: OGROpen(/vsimem/tempwfs_0x9cd770/file.gml/0xac0a00) succeeded as GML.
GML: ResetReading()
GML: ResetReading()
GML: ResetReading()
Extent: (61684.000000, 6605838.000000) - (732897.000000, 7776424.000000)
Layer SRS WKT:
PROJCS["ETRS89 / TM35FIN(E,N)",
GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AXIS["Latitude",NORTH],
AXIS["Longitude",EAST],
AUTHORITY["EPSG","4258"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",27],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","3067"]]
Geometry Column = the_geom
gml_id: String (0.0)
suuralue: String (0.0)
avi: String (0.0)
maakunta: String (0.0)
seutukunta: String (0.0)
kunta: String (0.0)
suural_ni1: String (0.0)
suural_ni2: String (0.0)
avi_ni1: String (0.0)
avi_ni2: String (0.0)
maaku_ni1: String (0.0)
maaku_ni2: String (0.0)
seutuk_ni1: String (0.0)
seutuk_ni2: String (0.0)
kunta_ni1: String (0.0)
kunta_ni2: String (0.0)
kieli_ni1: String (0.0)
kieli_ni2: String (0.0)
kaupunki: Integer (0.0)
shape_leng: Real (0.0)
shape_area: Real (0.0)
OGRFeature(lv:municipalities):1
gml_id (String) = municipalities.1
suuralue (String) = 4
avi (String) = 6
maakunta (String) = 19
seutukunta (String) = 197
kunta (String) = 890
suural_ni1 (String) = Pohjois-Suomi
suural_ni2 (String) = Norra Finland
avi_ni1 (String) = Lapin aluehallintovirasto
avi_ni2 (String) = Regionförvaltningsverket i Lappland
maaku_ni1 (String) = Lappi
maaku_ni2 (String) = Lappland
seutuk_ni1 (String) = Pohjois-Lapin seutukunta
seutuk_ni2 (String) = N_A
kunta_ni1 (String) = Utsjoki
kunta_ni2 (String) = N_A
kieli_ni1 (String) = Suomi
kieli_ni2 (String) = N_A
kaupunki (Integer) = 1
shape_leng (Real) = 348861.033197
shape_area (Real) = 5378678737.73
$ ogr2ogr -f "ESRI Shapefile" test.shp WFS:http://hip.latuviitta.org/cgi-
bin/tinyows municipalities -overwrite --debug on
OGR: OGROpen(WFS:http://hip.latuviitta.org/cgi-bin/tinyows/0x224fc60)
succeeded as WFS.
Shape: DBF Codepage = LDID/87 for test.shp
Shape: Treating as encoding 'ISO-8859-1'.
OGR: OGROpen(test.shp/0x2321b30) succeeded as ESRI Shapefile.
OGR: OGROpen(/vsimem/tempwfs_0x22d28f0/file.gml/0x2460c00) succeeded as GML.
GML: ResetReading()
GML: ResetReading()
Warning 1: Value '5378678737.729999542236328' of field shape_area has been
truncated to 24 characters.
This warning will not be emitted any more for that layer.
OGR2OGR: 343 features written in layer 'test'
> I am ready to surrender, though, with one tiny remark: Is is necessary to
> do at all the first getFeature with resulttype=hits if the next request is
> always a full getFeature? GDAL can count the number of features returned
> by thet second query and the resulttype=hits one can also be rather
> expensive for the WFS server.
I can understand that, but the key to understand the behaviour you observe is
that the OGR WFS driver has no idea that it is called in the context of
ogrinfo. So when ogrinfo issues a GetFeatureCount(), there's no reason to
issue a full GetFeature. Plus the fact that GetFeatureCount() is faster than
full GetFeature on big layers, so you might still be interested to know how
many features there are by just downloading a few bytes *before* issuing the
full GetFeature
> -Jukka Rahkonen-_______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
