[gdal-dev] PCT Pallete
Chaitanya kumar CH
chaitanya.ch at gmail.com
Tue Jan 10 14:34:00 EST 2012
Nikos,
The easiest way to create your own palette is described in the
documentation of the script[1]. You can use any raster file with a palette
as a source of palette. In the example in the script's documentation, a
dummy VRT file with a color palette is created and used.
[1]: http://www.gdal.org/rgb2pct.html
On Tue, Jan 10, 2012 at 11:44 PM, Nikolaos Hatzopoulos <nhatzop at gmail.com>wrote:
> How you can create your own pallet for the tool rgb2pct from existing rgb
> image.
> What kind of technics are existing in order to define such a pallete?
> --Nikos
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120111/37a87ebe/attachment.html
