[gdal-dev] Link against spatialite
Even Rouault
even.rouault at mines-paris.org
Wed Jan 11 17:14:10 EST 2012
Le mercredi 11 janvier 2012 17:43:44, prairie Last a écrit :
> I am trying to using the spatialite driver. According to the driver
> documentation, “creating or updating a spatialite database requires
> explicit linking against SpatiaLite library”. How do I explicitly link
> against the SpatiaLite library? Do I need to manually compile GDAL from
> source?
If you are on Windows, then you can use the builds at
http://vbkto.dyndns.org/sdk/ . They include spatialite 3.0 support.
For Linux, ping the packagers of your distro. If you cannot wait, then yes,
compile from source.
> Wenxuan
