[gdal-dev] Postgres/Postgis driver issue 1.8.1 and latest trunk
remoe
remo.eichenberger at gmail.com
Mon Jan 16 06:18:57 EST 2012
hi
i have an issue with postgres driver and SRID fetching from table. The
following code doesn't work correct on all cases:
When you have a table with NULL values in the geometry column, then this can
code returns an invalid SRID.
Why not get this information from geometry_columns - table ?
Thanks
Remo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Postgres-Postgis-driver-issue-1-8-1-and-latest-trunk-tp7192146p7192146.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
