[gdal-dev] Is this vsi* behavior intended?
Joaquim Luis jluis at ualg.pt
Sat Jan 21 17:17:07 EST 2012
On 21-01-2012 21:15, Even Rouault wrote:
>> Even,
>> Thanks for the explanation + fix but I was not aware that the correct
>> syntax is to use a double slash. The docs does not sate that and in fact
>> the examples there http://trac.osgeo.org/gdal/wiki/UserDocs/ReadInZip
>> show (for example)
>> ogrinfo -ro -al -so
>> /vsizip/vsicurl/http://svn.osgeo.org/gdal/trunk/autotest/ogr/data/poly.zip
> Yes, there is syntax sugar for combining /vsizip/ and /vsicurl/ where you are
> not obliged to repeat twice the slash between them, but however it seems not
> to exist for /vsigzip/ and /vsicurl/.
Ah, and will there be a 'gzsugarizing' op?
Also, I forgot ask before. The ACE2 driver says that elevation data is
return as float but what is the 'NoDataValue' for this?
