[gdal-dev] Is this vsi* behavior intended?
Joaquim Luis jluis at ualg.pt
Sat Jan 21 18:50:44 EST 2012
>> Also, I forgot ask before. The ACE2 driver says that elevation data is
>> return as float but what is the 'NoDataValue' for this?
> I don't know if there's an explicit nodata, but you can perhaps derive it from
> the source/quality/confidence layer datasets ?
> For example :
> gdalinfo
> /vsigzip//vsicurl/http://tethys.eaprs.cse.dmu.ac.uk/ACE2/links/ACE2_30_SECONDS/ACE2_30S_SOURCE/30N015W_SOURCE_30S.ACE2.gz
> -hist -stats
Thanks, but I think the quality of marine data (lousy) cooled down my
interest for this dataset.
Joaquim
