[gdal-dev] HDF-EOS AIRS CO2 images without georeference using
gdal_translate
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Jan 26 22:49:03 EST 2012
David,
I checked the images I created now. The GCPs were not considered. So, I
made sure they were used with gdalwarp.
gdalwarp -s_srs "EPSG:4326" -t_srs "EPSG:4326" -refine_gcps 200 10 -of
GTiff
HDF4_EOS:EOS_SWATH:"AIRS.2008.03.12.228.L2.CO2_Sup.v5.4.11.0.CO2.T09254115637.hdf":CO2:CO2ret
CO2_sup_Gtiff_EOS_warp.tif
I used the -refine_gcps. It will help in excluding the dummy gcps pointing
to (-9999,-9999,0). In this option, the number of minimum_gcps had to be
given. I chose the number 10 based on the number of usable GCPs available.
It should not be more than the number of usable GCPs. If I did not exclude
the dummy gcps, I got black image.
Also note that the output image dimensions changed.
On Fri, Jan 27, 2012 at 7:26 AM, David Ortiz <dvdov at yahoo.com> wrote:
> Hi Chaitanya
> Applying gdalinfo -stats to input and output images i get coherent values
> for statistics in both .img and GTiff images. The problem was in data
> display in GIS since QGIS show a Gtiff image with all pixel values equal to
> zero when i use "identify spatial objects" tool and ArcGIS doesn't display
> it correctly , just two lines and no data, but gvSIG allows see the
> appropriate values of CO2 amounts.
> However, neither the .img nor GTiff have geographical spatial reference in
> WGS84 datum coordinates. Even opening subdatasets directly from hdf file with
> ArcGis , the images are missing georeference. As it is seen below, hdf
> image is between -133.57, -157.94 longitudes and 22.23, 45.88 latitudes. I
> mentioned HDF_SDS:UNKNOWN datasets on previous post because it have some
> info about coordinate reference system:
> SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
> Actually , when i load Geotiff generated with HEGTool (with other AIRS
> products) in any gis software , automatically have wgs84 Datum coordinates
> Here the results of gdalinfo command:
> 1. Input image
> gdalinfo -stats
> HDF4_EOS:EOS_SWATH:"/home/david/Descargas/pruebas/AIRS.2008.03.12.228.L2.CO2_Sup.v5.4.11.0.CO2.T09254115637.hdf":CO2:CO2ret
> Driver: HDF4Image/HDF4 Dataset
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 22.0)
> Upper Right ( 15.0, 0.0)
> Lower Right ( 15.0, 22.0)
> Center ( 7.5, 11.0)
> Band 1 Block=15x22 Type=Float32, ColorInterp=Gray
> Min=379.197 Max=393.697
> Minimum=379.197, Maximum=393.697, Mean=386.463, StdDev=3.071
> NoData Value=-9999
> Metadata:
> STATISTICS_MAXIMUM=393.6969909668
> STATISTICS_MEAN=386.46261742001
> STATISTICS_MINIMUM=379.1969909668
> STATISTICS_STDDEV=3.0709672735453
> 2. with Geotiff output image :
> gdalinfo -stats
> /home/david/Descargas/pruebas/EOS/CO2_sup_Gtiff_EOS_traslate.tif
> Driver: GTiff/GeoTIFF
> Files: /home/david/Descargas/pruebas/EOS/CO2_sup_Gtiff_EOS_traslate.tif
> /home/david/Descargas/pruebas/EOS/CO2_sup_Gtiff_EOS_traslate.tif.aux.xml
> Size is 15, 22
> Coordinate System is `'
> GCP Projection =
> GCP[ 0]: Id=1, Info=
> (0.5,0.5) -> (-9999,-9999,0)
> GCP[ 1]: Id=2, Info=
> (1.5,0.5) -> (-9999,-9999,0)
> GCP[ 2]: Id=3, Info=
> (2.5,0.5) -> (-9999,-9999,0)
> GCP[ 3]: Id=4, Info=
> (3.5,0.5) -> (-145.229995727539,23.3500003814697,0)
> GCP[ 4]: Id=5, Info=
> (4.5,0.5) -> (-9999,-9999,0)
> GROUP = HORIZONTALSPATIALDOMAINCONTAINER
> GROUP = BOUNDINGRECTANGLE
> OBJECT = EASTBOUNDINGCOORDINATE
> NUM_VAL = 1
> VALUE = -133.537399291992
> END_OBJECT = EASTBOUNDINGCOORDINATE
> OBJECT = WESTBOUNDINGCOORDINATE
> NUM_VAL = 1
> VALUE = -157.941314697266
> END_OBJECT = WESTBOUNDINGCOORDINATE
> OBJECT = SOUTHBOUNDINGCOORDINATE
> NUM_VAL = 1
> VALUE = 22.2317676544189
> END_OBJECT = SOUTHBOUNDINGCOORDINATE
> OBJECT = NORTHBOUNDINGCOORDINATE
> NUM_VAL = 1
> VALUE = 45.889762878418
> END_OBJECT = NORTHBOUNDINGCOORDINATE
> END_GROUP = BOUNDINGRECTANGLE
> INTERLEAVE=BAND
> Corner Coordinates:
> Center ( 7.5, 11.0)
> NoData Value=-9999
> Metadata:
> 3. .img image :
> gdalinfo -stats /home/david/Descargas/pruebas/EOS/CO2_sup_img_EOS.img
> Driver: HFA/Erdas Imagine Images (.img)
> Files: /home/david/Descargas/pruebas/EOS/CO2_sup_img_EOS.img
> /home/david/Descargas/pruebas/EOS/CO2_sup_img_EOS.img.aux.xml
> Size is 15, 22
> GROUP = SPATIALDOMAINCONTAINER
> NUM_VAL = 1
> NUM_VAL = 1
> NUM_VAL = 1
> NUM_VAL = 1
> Corner Coordinates:
> Center ( 7.5, 11.0)
> Band 1 Block=64x64 Type=Float32, ColorInterp=Undefined
> Description = Layer_1
> NoData Value=-9999
> Metadata:
> LAYER_TYPE=athematic
> What is wrong?. I tried with gdal 1.8 and 1.9 with hdf4 support.
> Best regards.
> David Ortiz V.
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120127/f30781b4/attachment-0001.html
