[gdal-dev] gdalwarp makes landcover files blocky when shrinking
pixel size
John Twilley
mathuin at gmail.com
Fri Jan 27 14:58:04 EST 2012
None of those resampling methods are well-suited to classified rasters
as far as I can tell.
The method that has worked best in the past was to take the majority
of a number of the nearest neighbors. The 'mode' algorithm in
gdaladdo may do that, but I haven't checked the source code.
Jack.
mathuin at gmail dot com
2012/1/27 Dmitry Baryshnikov <polimax at mail.ru>:
> 27.01.2012 23:30, John Twilley пишет:
>> Cubic is fine for the elevation, but it doesn't work on the landcover.
>> which is the problem I originally mentioned.
>> Jack.
>> 2012/1/27 Dmitry Baryshnikov<polimax at mail.ru>:
>>> 27.01.2012 20:19, John Twilley пишет:
>>>> After retrieving the files and building VRTs from them, I run the
>>>> following gdalwarp commands:
>>>> gdalwarp -q -multi -t_srs "+proj=aea +datum=NAD83 +lat_1=29.5
>>>> +lat_2=45.5 +lat_0=23 +lon_0=-96 +x_0=0 +y_0=0 +units=m" -tr 6 6 -te
>>>> 2002944 2271744 2016768 2288640 \
>>>> -srcnodata -340282346638528859811704183484516925440 -dstnodata 0
>>>> ND302HT.vrt ND302HT.tif
>>>> -srcnodata 255 -dstnodata 11 L0102HT.vrt L0102HT.tif
>>>> The only differences between the lines are the nodata values.
>>>> Jack.
>>>> On Thu, Jan 26, 2012 at 22:49, Dmitry Baryshnikov<polimax at mail.ru>
>>>> wrote:
>>>>> 27.01.2012 3:39, John Twilley пишет:
>>>>>> I am working with elevation and landcover data downloaded from the
>>>>>> USGS. I use gdalwarp to convert the data to a much smaller pixel. The
>>>>>> elevation data works very nicely with cubic resampling, but the only
>>>>>> resampling that works at all for the landcover data is
>>>>>> nearest-neighbor and that's very blocky. When I last worked with
>>>>>> landcover data, I used a majority algorithm which produced smoother
>>>>>> output -- but that algorithm is not implemented in gdalwarp.
>>>>>> I am looking over the source to gdalwarp to see how hard it is to add
>>>>>> a new algorithm. Other than that, though, what options are available
>>>>>> to me? Thanks in advance!
>>>>>> Jack.--
>>>>>> _______________________________________________
>>>>>> gdal-dev mailing list
>>>>>> gdal-dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>> Hi John,
>>>>> That is your command line string for gdalwarp?
>>>>> Best regards,
>>>>> Dmitry
>>> Hi John,
>>> Try to add "-r cubic" command parameter
>>> For example:
>>> +lat_2=45.5 +lat_0=23 +lon_0=-96 +x_0=0 +y_0=0 +units=m" -tr 6 6 -r cubic
>>> -te
>>> You can found additional parameters description here:
>>> http://www.gdal.org/gdalwarp.html
>>> I have tested -r parameter and it works.
>>> Best regards,
>>> Dmitry
> Hi John,
> You can use resampling methods:
> near: nearest neighbour resampling (default, fastest algorithm, worst
> interpolation quality).
> bilinear: bilinear resampling.
> cubic: cubic resampling.
> cubicspline: cubic spline resampling.
> lanczos: Lanczos windowed sinc resampling.
> And what method do you need?
> Best regards,
> Dmitry
