[gdal-dev] Building Improvment for Ingres driver in Windows
Dmitry Baryshnikov
polimax at mail.ru
Mon Jan 30 02:46:30 EST 2012
30.01.2012 10:53, chen zhen пишет:
> Hi all,
> It is great to know the Ingres driver pulled from SVN has been compiled successfully.
> However it is not flexible enough or in other word, a little improvement should be applied:
> 1. One switch for turn on/off the Ingres definition. Currently by uncomment several definitions in nmake.opt is a little complex. Also the header files and library files directories must be specified by hand. After Installing the Ingres database, the locations of this file are fixed. It would be better to set the default path related to a variable such as $(ING_HOME). ING_HOME variable could be set to II_SYSTEM previously and let it detected automatically. If the ING_HOME is set, then Ingres driver will be involved.
> # nmake.opt
> # INGRES Libraries
> # Uncomment the following to enable Ingres format.
> # INGRES_HOME = $(II_SYSTEM)
> !ifdef INGRES_HOME
> INGRES_INC_DIR = $(INGRES_DIR)\files
> INGRES_LIB = $(INGRES_DIR)\lib\iilibapi.lib \
> $(INGRES_DIR)\lib\iilibutil.lib \
> $(INGRES_DIR)\lib\libingres.lib
> !endif
> 2. Building Ingres driver as a plugin library. It is not necessary but provides more flexibility especially for Ingres that needs a number of dependent libraries.
> The Ingres_Plgin flag is set to check which mode would it be.
> # nmake.opt
> # INGRES Libraries
> # Uncomment the following if you prefer to build Ingres support as a plugin.
> # INGRES_PLUGIN = YES
> !ifdef INGRES_HOME
> !endif
> Any idea?
> zhen
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
By my opinion, the cmake will more flexible in path searching and
setting all necessary definitions.
I'm playing with cmake building of gdal (but not final version yet).
What do you think about cmake building of GDAL?
Best regards,
Dmitry
