[gdal-dev] empty Gtiff from Python
questions anon
questions.anon at gmail.com
Tue Jan 31 23:40:50 EST 2012
Was this problem solved?
I have tried both
dst_ds.GetRasterBand(1).WriteArray(myarray)
gdal.Band.WriteArray(dst_ds.GetRasterBand(1), myarray)
but my tiff still results in zeros.
Any feedback will be greatly appreciated.
On Fri, Oct 28, 2011 at 7:23 PM, Tom van der Putte <tom at vdputte.nl> wrote:
> Hi List,
> I'm trying to save a numpy array to a GTiff, which should be quite
> straightforward, considering all the examples available on the web.
> However, I get an file that is not readable by Qgis, is regarded by ArcMap
> to have only 0 and gdalinfo displays nothing on the values.
> I start with a ndarray, dtype = int32, shape = ( 10,10). It has integer
> values between 1 and 10. The code is as follows:
> import numpy as np
> from osgeo import gdal
> from osgeo import osr
> #np array
> a = np.ones((10,10))
> #coord-system
> sr_str = 'LOCAL_CS["arbitrary"]'
> sr = osr.SpatialReference( sr_str )
> #driver
> driver = gdal.GetDriverByName("GTiff")
> #dataset
> ds = driver.Create("D:\\temp\\output.tif", 10, 10, 1, gdal.GDT_Byte)
> ds.SetProjection( sr_str )
> ds.SetGeoTransform((0, 1, 0,0, 0,1))
> #write and close
> ds.GetRasterBand(1).WriteArray(a)
> ds = None
> The corresponding gdalinfo is:
> Raster dataset parameters:
> Projection:
> LOCAL_CS["arbitrary",UNIT["metre",1,AUTHORITY["EPSG","9001"]]]
> RasterCount: 1
> RasterSize (10,10)
> Using driver GeoTIFF
> Metadata:
> 0: AREA_OR_POINT=Area
> Image Structure Metadata:
> 0: INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left (0, 0)
> Lower Left (0, 10)
> Upper Right (10, 0)
> Lower Right (10, 10)
> Center (5, 5)
> Coordinate System is:
> UNIT["metre",1,
> Band 1 :
> DataType: Byte
> ColorInterpretation: Gray
> Description:
> Size (10,10)
> BlockSize (10,10)
> I have tried both version 1.6.3 (I'm trying to make a Qgis plugin, and
> thus restricted to 1.6.3) as well as 1.8.1. I have also tried ds =
> driver.Create("D:\\temp\\output.tif", 10, 10, 1, gdal.GDT_Int32), but that
> didn't make much difference.
> I tried to make a Surfer grid (GSBG), and this somewhat worked: it gave a
> nice picture, but the values were off the charts.
> Any clues as to what I'm missing here? Cheers,
> Tom van der Putte
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120201/6738f0c6/attachment.html
