[gdal-dev] UnsatisfiedLinkError: building with Swig Java bindings
kedardeshpande87
kedardeshpande87 at gmail.com
Mon Jul 2 07:56:21 PDT 2012
I am trying to build from source with Java bindings. I compiled the regular
source with configure, make and make install first and then ran the GNUmake
file from the gdal/swig/java directory. Now, I have created a small cmdline
application in Java and I am trying to run it. It gets compiled. But when I
run it, I am getting this UnsatisfiedLinkError :
java.lang.UnsatisfiedLinkError: .../gdal/build/.libs/libgdal.so.1: undefined
symbol: _ZTVN6PCIDSK15PCIDSKExceptionE
Is there something I am missing here?
I have put gdal.jar in classpath and these files in java.library.path :
libgdaljni.so, libosrjni.so, linogrjni.so, libgdalconstjni.so, libgdal.so
Is there something more that I need to put in classpath or java library path
or set any environment variable?
Can you please provide me a full list of jars/files/env-variables that I
need to set to make it run ?
Thanks,
Kedar
View this message in context: http://osgeo-org.1560.n6.nabble.com/UnsatisfiedLinkError-building-with-Swig-Java-bindings-tp4985371.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
