[gdal-dev] How to read GML/GeoRSS directly from XML string?
Even Rouault
even.rouault at mines-paris.org
Thu Jul 5 11:47:39 PDT 2012
Le jeudi 05 juillet 2012 20:44:58, Yingqi Tang a écrit :
> Hi Chaitanya,
> GeoJSON does seem to be an exception, although the ogr driver can directly
> read the GeoJSON string, the generic virtual memory file doesn't seem to
> work:
> inputDataStr = "{geojson_string}";
> gdal.FileFromMemBuffer('/vsimem/temp', inputDataStr);
> inputDriver.Open('/vsimem/temp', 0);
> Is that expected?
Yes, the geojson driver only recognizes filenames ending with .json or
.geojson, so use "/vsitem/temp.json" as a filename.
