[gdal-dev] Building from source excluding some packages
kedardeshpande87
kedardeshpande87 at gmail.com
Thu Jul 5 16:50:32 PDT 2012
Thanks Paolo,
I tried building it with minimal options as you suggested. The source builds
successfully, but when I try to use the library by making a call, I am
getting an error in libgdal.so file saying some symbol not found. I am using
swig java bindings.
I get the following error:
UnsatisfiedLinkError: .../build/lib/libogrjni.so:
.../gdal/build/.libs/libgdal.so.1 undefined symbol <symbol_name>
It finds the required .so files in java.library.path but the libgdal.so.1
file does not contain the symbol because we excluded some parts of source
while building.
For example, when I provide --without-jpeg option while configuring, I get
the error undefined symbol 'jpeg_resync_to_restart'.
For some other format I exclude, I get the same error for some other symbol
from that package.
So, specifying the --without-PACKAGE option builds the code but some of the
references are still pointing nowhere because the package was excluded. and
I am getting an exception at runtime.
Can you please let me know how do I resolve this ?
Thanks!
Kedar
View this message in context: http://osgeo-org.1560.n6.nabble.com/Building-from-source-excluding-some-packages-tp4983703p4986405.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
