[gdal-dev] gdal_merge.py on large Tiff's. gdalwarp not working properly.
aphunter
a1hunter at ucsd.edu
Sun Jul 8 19:19:33 PDT 2012
Hi Jean-Claude. Thanks for the idea. Unfortunately it made the split a little
larger. Is it possible to make the borders transparent, or remove them so
the blending works properly as it does in gdal_merge.py?
Thanks,
Aaron
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-merge-py-on-large-Tiff-s-gdalwarp-not-working-properly-tp4986729p4986806.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
