[gdal-dev] GDAL and Kakadu v7 SDK
Kolomeitz Shaun
Shaun.Kolomeitz at derm.qld.gov.au
Mon Jul 9 21:41:48 PDT 2012
Thanks Even,
Much appreciated.
That seems to have worked (although not thoroughly tested), at least for GDAL-2x.
We have v7 of the Kakadu SDK and I will persevere with this version and look at the JNI bindings now and the geoserver imageIO extension.
Kind regards,
Shaun
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Monday, 9 July 2012 5:33 PM
To: gdal-dev at lists.osgeo.org
Cc: Kolomeitz Shaun
Subject: Re: [gdal-dev] GDAL and Kakadu v7 SDK
Le lundi 09 juillet 2012 03:07:06, Kolomeitz Shaun a écrit :
> Does anyone happen to know how to get Kakadu v7 SDK to compile
> successfully into GDAL under 64bit Debian Linux please ?
Shaun,
I don't think so. Apparently there are a few changes that would be needed to support Kakadu v7. See http://trac.osgeo.org/gdal/ticket/4575 for some suggested changes (not yet committed). Otherwise, you should stick with Kakadu v6.x if you have it available
The information in this email together with any attachments is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. There is no waiver of any confidentiality/privilege by your inadvertent receipt of this material.
Any form of review, disclosure, modification, distribution and/or publication of this email message is prohibited, unless as a necessary part of Departmental business.
If you have received this message in error, you are asked to inform the sender as quickly as possible and delete this message and any copies of this message from your computer and/or your computer system network.
