[gdal-dev] Ogr to access MSSQL DB
Tamas Szekeres szekerest at gmail.com
Wed Jul 11 07:15:19 PDT 2012
It is required with the current ogr driver, however we could implement some
support to eliminate. This table is anyway included in the simple features
specification for databases standard.
If you create the layers by using ogr (ie. by using ogr2ogr command line
tool) the metadata tables are also created if necessary.
Best regards,
Tamas
2012/7/11 Benjamin <benjamin.lux at maxsea.fr>
> Is the geometry_columns table mandatory ?
> Because I have not such table.
> This table is not in the spatial standard, isn't it ?
> Ogr need to acces it ?
> If yes, I think I will have to create it.
> Thx for the clue,
> Benjamin.
> http://osgeo-org.1560.n6.nabble.com/gdal-dev-Ogr-to-access-MSSQL-DB-tp4987592p4987674.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120711/4d8931d5/attachment.html>
