[gdal-dev] Error handlers in Python bindings
Even Rouault
even.rouault at mines-paris.org
Thu Jul 12 01:59:41 PDT 2012
Selon lpinner <Luke.Pinner at environment.gov.au>:
> The python function needs to accept three arguments, error class, error code
> and error message.
> i.e.
> from osgeo import gdal
> def f(err_class, err_code, msg):
> print err_class, err_code, msg
> gdal.PushErrorHandler(f)
Reviewing the Python bindings code, I see no evidence that Python error handlers
are possible. An option is to use gdal.UseExceptions() which will cause a Python
exception to be thrown after a GDAL call has emitted an error.
http://osgeo-org.1560.n6.nabble.com/gdal-dev-Error-handlers-in-Python-bindings-tp4987591p4987809.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
